102MM Boost Issues
Old Sep 13, 2017 | 05:52 PM
  #41
C5Natie's Avatar
C5Natie
Turbo-Geist, the NW tb opens from the bottom outward. So do you mean flipping it around so it opens from the top outward may help? Maybe the air has more leverage opening the tb that way so it stays open at WOT?
Old Dec 8, 2017 | 12:14 PM
  #42
nutbuster's Avatar
nutbuster
Default Nick Williams
I bought the Nick Williams throttle body for the boosted application, 750.00$. Still had a reduced engine power problem. It wasn't until I put a stock LS2 throttle body on that it fixed my problem. My setup was an LSX 427 with an F1X pro charger.
Old Dec 8, 2017 | 08:06 PM
  #43
silver408z's Avatar
silver408z
I had a NW on my old setup and did not have issues. Mine was a little older NW 102 and actually had a c5 motor on it not a c6. 102 TB's also make a big difference on positive displacement blowers and less on centi blowers or turbos. The TB is before the blower and being sucked through and blown through.
I was told one time that pretty much all the power adders are good pushers but are bad suckers. Restricting the suction makes it worse.
Old Dec 9, 2017 | 06:46 PM
  #44
typeav's Avatar
typeav
Nick Williams 102mm will go down as the most hated Throttle Body in history, I said it.
Old Dec 9, 2017 | 08:25 PM
  #45
helga203's Avatar
helga203
For a boosted application that is.
Old Dec 10, 2017 | 09:27 PM
  #46
typeav's Avatar
typeav
Never work for me with a mild cam and N/A engine, I had multiple tuners but never worked. It was a very expensive deception experience, the LS2 throttle body works like a charm.
Old Dec 10, 2017 | 09:30 PM
  #47
typeav's Avatar
typeav
To detail it a little better, tuners can make it work in the dyno for a while but I swear, before you reach home you will start getting all kind of P1XXX computer error codes and the engine failing at every corner.
Old Dec 12, 2017 | 10:52 AM
  #48
helga203's Avatar
helga203
You diffently are not the only one that had issues with it. I don't know how they get away with selling it as a boosted throttle body.
Old Dec 12, 2017 | 11:51 AM
  #49
typeav's Avatar
typeav
Does anybody know anything about this other 102mm throttle body from TPiS ?
https://www.tpis.com/pages/8_10_11
Old Sep 13, 2018 | 09:48 PM
  #50
_zebra's Avatar
_zebra
Originally Posted by 95vettski
In a boosted application no need for a larger tb. I have made 920rwhp with a stock 78mm tb. Plus I have read of many complaints with the NW tb even when normally aspirated.
actually, that depends on what kind of boost maker you're using. see below...
yep, a top-mount supercharger will definitely start pulling vacuum behind a TB that's too small if you spin it fast enough... just the same as a centri, when spun hard, will pull vacuum on the supplied filter/intake pipe, driving dudes to make 4" versions.
and i know it's from last year, but i found this searching for boost-friendly 102 TBs & wanted to clear up a little mis-information.
Old Sep 14, 2018 | 09:58 AM
  #51
BLOWNBLUEZ06@RKT Performance's Avatar
Supporting Vendor
My .02 on the subject:
If you are N/A or have a PD-style blower, like a Maggie and want to gain a relative idea of how much there is to be gained with a throttle body swap, remove all restrictions from in front of your existing throttle body and get a good, high resolution vacuum gauge or even a MAP sensor and tap into the intake area behind the throttle body and log the difference between the readings with the engine off and the vacuum readings at WOT. Any vacuum will be a reflection of how much restriction to flow your throttle body is creating. The same can be done with tapping into the area between the filter and blower inlet on a centrifugal setup or a turbo setup.
As for issues with throttle bodies, I've run the fairly new Nick Williams throttle body that's designed for boost up to 39+psi so far without any issues.
Bret
__________________
Offering products from A&A Superchargers, East Coast Superchargers, Mechman Alternators, Mantic clutches, RPS clutches, Kooks Headers, Lakewood, LG, Brian Tooley Racing, Comp Cams, FAST, ARP, UPP Turbo systems, Wiseco, Callies, K1, MAST Motorsports, Haltech and many more. PM me for details.
Old Sep 14, 2018 | 10:06 AM
  #52
Turpid porpoise's Avatar
Turpid porpoise
Interesting that they seem to have used the OEM LS2 motor on their own billet TB. I'd be open to trying it but I'm not on stock PCM so REP mode is not an issue for me.
Old Sep 15, 2018 | 08:08 AM
  #53
HardcoreABN's Avatar
HardcoreABN
For me, it isn't worth it.. the problems with the NW throttle bodies - both the original and the "boost" model are well documented. I will stick with my 90mm LS2 throttle body that is pretty much flawless.
