Alky pump install question
Old Sep 15, 2018 | 06:49 PM
ascastil's Avatar
ascastil
Default Alky pump install question
The directions say if you're mounting it to the frame to install an oring on a bolt to ground it. What do I just grab an oring and slap it onto the threaded part of one of the self tapping screws, I don't get it?
Old Sep 15, 2018 | 06:55 PM
ascastil's Avatar
ascastil
Also, the pump I have looks difft than what's in the pics in the instructions. It also has 4 rubber pieces already where the screws pass through.
Old Sep 15, 2018 | 07:15 PM
StingrayRebel's Avatar
StingrayRebel
are you talking about the white wire coming out of the pump with a ring terminal on it?... just sand a small exposed area on the frame and tighten that wire to the frame with a self tapping screw and put a little silicone grease on that area
Old Sep 15, 2018 | 07:20 PM
ascastil's Avatar
ascastil
Haven't seen any mention of the white wire yet. The directions say use 4 self tapping screws to mount pump. The next sentence says if mounting to metal, place an oring on one of the screws, that will ground it.
Old Sep 15, 2018 | 07:25 PM
StingrayRebel
I'm pretty sure they are referring to that white wire, I grounded mine to the frame in a different location and did not use the pump mount screws as the ground point
Old Sep 15, 2018 | 07:50 PM
ascastil's Avatar
ascastil
Ok Thank you for the quick response. Back to work.
To Alky pump install question
