MSD 2 step issues
Old Oct 31, 2017 | 07:20 PM
03DSGVERT3985's Avatar
03DSGVERT3985
Default MSD 2 step issues
I purchased this car and found a two step wired up. When the key is in the on position the red light is activated. Doesn’t matter if the clutch pedal is pushed or not. Once the car is started the light will not activate.
Looks like the clutch safety switch (lowest one on firewall) has had the wires replaced. One wire running to ground the other to the blue wire on the MSD box.
From reading other threads that seems like ok wiring to activate the 2 step by ground but it isn’t working.
Any ideas
