ARP Flywheel bolts with Mantic twin disc 9000 series
Quick one since im doing my Clutch install.
ARP Flywheel bolts heads are .100" thicker than stocker.
They doesnt seems to rub the spring disc but better be safe than sorry and ask.
Any issue with ARP Flywheel bolts with twin Clutch ???
Eric
Eric
There are issues with ARP bolts on a few clutches.
Speak to your clutch supplier with regards yours, or test prior to installation
ARP flex plate bolts have a shallow head and generally a better design
Well they where too close to my taste.
i would imagine that has the Clutch disc wears out the spring would come even closer and rub the spring.
I chose to use the one that came with the Mantic Flywheel.
Now i gotta find if its normal that i need a .250" Shim behind the slave...seems a lot...
Will make another thread with exact measurement for m'y Clutch/slave issue.
