Zo6 vent under intake
The Valve cover will draw fresh air from my supercharger inlet air filter.
Catch Can routing.pdf
Attachment 48280417
also you did not mention what is making the boost, but if it is turbo or centri-sc the diagram attached previously will immediately fail your main seal(s)
if you have any questions specific to what i do differently and why. i am happy to help.
my solution for this is called my C5/6 Wild system.
https://www.mightymousesolutions.com...page/c5-6-wild
many of the configurations in that pdf are totally a bad idea IMO; but just follow the can manufacturers instructions closely.. using 'random' ones off the internet is asking for trouble.
the open end / fresh air / clean side is to let clean air in to replace dirty air being drawn out to manifold (crankcase filtration process) and to provide an escape path for high load blow-by.
this open end connects post-maf sensor on maf equipped cars so that during the vacuum cycle the air that is used (and ultimately ends up with the rest of the intake air in the manifold) is also measured.
If there's no fresh air intake, the crankcase fills with blow-by (exhaust gas, basically) and the intake manifold sucks out what it can. But the crankcase gas is pretty much 100% blow-by (exhaust gas, some air, some raw fuel).
If there is a fresh air intake, there is a constant flow of air through the case, drawn by the intake manifold. Of course there's almost no draw at full throttle, but there's some flow at idle and part-throttle. But the case contents are a mix of fresh air and blow-by. I'm not sure about this but I think that emissions rules require the fresh air inlet so that blow-by gets continuously sucked through the engine and burned, rather than just accumulating and seeping into the atmosphere when the engine is stopped.
For a boosted car...
It's more complicated because the intake manifold alternates between lower-than-atmospheric and higher-than-atmospheric pressure. My Subaru's stock system has two modes of operation - with intake manifold vacuum, it pulls from the crankcase center port and fresh air comes in via breathers on both heads, with the supply coming from a post-MAF, pre-turbo fitting, so that the intake vacuum is only pulling in metered air (and blow-by). Under boost, the intake manifold check-valve closes, and both heads and the center case port all vent exhaust gas to that same post-MAF, pre-turbo fitting. There's a T-valve above the case port with one leg going to the intake manifold and the other going to the pre-turbo fitting, with a restriction on the pre-turbo line so that intake vaccuum mostly pulls from the case rather than from the turbo inlet (which would defeat the crankcase ventilation aspect). There are diagrams here if you're curious about how an OEM does PCV with forced induction:
http://www.iwsti.com/forums/2-5-lite...ns-thread.html
Lots of Subaru people just configure all three case ports as outflow vents, going into a catch can and then to that post-MAF, pre-turbo fitting. Being post-MAF, it is unmetered, but it's also either exhaust gas (no free oxygen), or unburned air/fuel mix (oxygen balanced with fuel), so it doesn't affect AFR enough to matter.
IMO the ideal setup would work similarly to the OEM Subaru setup but with two catch cans - one attached to the intake manifold to collect crap when the you're driving in vaccum, and one attached to a fitting behind the air filter, to collect crap when you're driving in boost. That's a lot of plumbing though.
If there is a fresh air intake, there is a constant flow of air through the case, drawn by the intake manifold. Of course there's almost no draw at full throttle, but there's some flow at idle and part-throttle. But the case contents are a mix of fresh air and blow-by. I'm not sure about this but I think that emissions rules require the fresh air inlet so that blow-by gets continuously sucked through the engine and burned, rather than just accumulating and seeping into the atmosphere when the engine is stopped"
I agree in part but the only time the intake can "suck" out blow-by is when the vacuum in the intake exceeds the pressure in the crankcase. So at cruse, the vacuum will likely exceed the crankcase blow-by pressure and a "suction" will occur (suction strength will be determined by whatever amount manifold vacuum exceeds blow-by pressure). In this case a fresh air supply will be required to make-up the air vacuumed from the intake. Otherwise a vacuum would exist in the crankcase and the seals could fail "inward" not "outward as would happen with excess pressure.
At higher throttle openings manifold vacuum will be reduced until crankcase pressure will exceed vacuum and no fresh air can be "sucked" in - actually crankcase air will be "pushed" out.
Can you agree with this statement to this point?
Dry-sump setups keep the crankcase below atmospheric pressure all the time, but I don't know how far below, or whether they use the same seals as wet-sump engines. Does anyone know if they seals changed when GM started putting dry sumps in LS7s?
Thinking about this some more, I wonder if oil life is affected to any measurable degree on a street car that has no air flowing through the case... The oil would basically be surrounded by exhaust gas all the time, plus some raw fuel and air (from blow-by during the compression strokes). I ran my Subaru that way for years (all ports routed to the air intake) and never noticed any issues but also never had any oil analysis done back then.
so this 99.9x% of the time is when the pcv's 'filtration cycle' is occurring
:regulated intake manifold vacuum IS enough to not only scavenge the crankcase completely, but 'pull' clean air in to replace the foul air extracted
on wide open for n/a there can be some pcv flow still as there is light suction at the intake manifold, but for a boosted app obviously we want this path closed
on a car trying to make it a full term oil change, oil cleanliness is absolutely negatively affected by the pcv system being removed
that Subaru stuff is unnecessarily complex imo! and two cans arent needed imo, and only two hoses on a good one are (imo).
clean air in -> crankcase -> dirty air out -> GOOD catch can
-> intake manifold
