Ugh- shredding belt with ATI already
Re: Ugh- shredding belt with ATI already (jeff_nation)
I shredded rubber like crazy before I moved to an 8 ribbed belt and an adjustable tensioner pulley. Now I pull 10lbs at 6000rpm's with NO slippage.
I know this can be a real pain in the boost!
Whose tensioner, Katech or other?
Speedworks in Dallas did your install?
Re: Ugh- shredding belt with ATI already (Rookiedyn)
If they are reading the Forum and want truthfull information. Please have them start a thread so we can give them our personal experiences. :yesnod: I would like to let them know directly what I have encountered with the PS1 kit. By letting them know the issues, they can build a better product for all the future S/C owners.
vetterdstr :cheers:
vetterdstr :cheers:
It sucks for sure...Also watch out as the hood liner will shread with the belt!! When i crawled under the car, i noticed the belt was within a hair of touching the the block...I also tried the Katech manual tensioner, turns out, IT was the reason i had slippage! Put the stock tensioner on, bingo full boost....It really helps to secure the car safely, then get underneath and watch the belt as it turns to see where it may be touching..Above posts should help you fix your problem :cheers:
Re: Ugh- shredding belt with ATI already (dbvettez06)
Shinobi'sZ was right on the money with his explanation. Just got of the phone with my tuner and they had to take .60 off the idler pulley. They found where the belt rode up the pulley and over and sliced one of the ribs. They put everything back together and checked it with a laser level and everything seems perfect. We arent sure why it didn't happen on the dyno and then during the first 150 miles on the road but as I put more miles on her the answers will come.
I am going to show him what Andy has developed when I pick up the car. My tuner is very interested in making fixes to the kit to help aide future installs. We can only hope ATI is researching this forum as noted in another thread.
Next will be to test overheating issues. Of course being its in the 30's and low 40s here already that will have to wait till spring.
All the small problems are an invonvenience but those that run the ATI know its worth the trade off once things are right. The performance gain is amazing and drives like the car came from the factory untill you get on it.
Rookiedyn,
I am glad it worked out for you. I am in the process of selecting my next pully, as I think I am running between 10-12 lbs of boost. I am using a 3.85" pully...what size pully did you use to get 8 lbs of boost?
Boy, am I glad I read this. I was seriously considering the Procharger and had even gotten a price from an installer about an hour away. I think I will have to hold off until ATI gets everything straightened out as this is my daily driver and I can't afford to be continually making repairs and adjustments. Thanks for all of the input.
Come on ATI, come to the rescue!
Re: Ugh- shredding belt with ATI already (Shinobi'sZ)
Rookiedyn,
Re: Ugh- shredding belt with ATI already (MH2Lmaker)
