Gates Belt
It's not the RPM type, just a 'stock' type of the shelf of an autopart store/chain. Should it still work, or do I need a more racing type?
I used a DayCo standard off the shelf belt for two years without incident.
If it split, have you checked the line the belt follows for sharp contacts? I don't know your kit or quite where the belt is routed for you, but if a manual or spring tensioner were to fail, or let's say at higher rpm they extend open more, the belt could have been coming in contact with a sharp contact point and prompting the split. Easy enough to check and verify. Are there any areas near belt travel with rubber or powder debris?
Edit: If you do find an RPM belt for your application's desired length, some have reported them being difficult to install. I just installed mine two days ago and it was no problem. In my case, I have an AA bracket with a Procharger. This bracket has a spring tensioner and a manual tensioner. With full force on the manual tensioner, the point at which the bolt locks in place is a full inch different from where it had been previously. So while it is not impossible to install, it does seem to either stretch less or be slightly shorter. I did not take a tape measure to it.
25-060896 on my Novi 2000
