Help FP issue
Old 06-27-2018, 08:16 PM
TJ_C598
TJ_C598's Avatar
Default Help FP issue
Look for some assistance. I have a 98 C5 with a novi2000. 9-10 psi. I am getting a dyno tune and the AFRs are raising at 6k rpm. AFR12.0, measuring 540rwhp. I have a racetronix pump with a BAP. Everything I find says this set up should support 600rwhp for a FI setup. Stock rails and lines, 80lbs injectors. What am I missing? Where should I be looking? Any advance is appreciated. Thanks
Old 06-28-2018, 07:01 AM
Turpid porpoise
Turpid porpoise's Avatar
Fuel pump could be going bad, it is a 20 year old car now. When was the fuel filter last changed? Are you still using the stock regulator or aftermarket?
Old 06-28-2018, 01:28 PM
SmoothFRC
SmoothFRC's Avatar
+1 on the filter, that has given me issues in the past.
You mentioned racetronixs pump, are you also running the hotwire kit? I assume so with the BAP - if not, you'll want/need that.
Old 06-28-2018, 03:44 PM
BLOWNBLUEZ06@RKT Performance
Supporting Vendor
BLOWNBLUEZ06@RKT Performance's Avatar
I don't recall if the Racetronix harness has a ground strap, but if it's not already there, you need to make sure you put a short, 10ga ground strap between one of the bolts on the fuel hat and the frame. If you have any deficit in the grounding, this provides a secondary path since the pump should also be grounded to the hat from inside too.
Bret
Old 06-28-2018, 04:17 PM
Turpid porpoise
Bret
If my memory is correct the ractronix harness does have a ground wire near the fuel hat but it may only be 12-14AWG. I also second the hotwire harness, easy to install and help combat voltage drop at the pump.
Old 07-13-2018, 09:39 AM
romandian
romandian's Avatar
you will always see a drop in fuel pressure with this system. its pretty proportional to injector duty. did you measure fp and how?
To Help FP issue
Quick Reply: Help FP issue
