ls3 or lsx for boost
Thanks!
It will probably give you a little more torque but when you talk to engine builders not all of them like the geometry of a 4" stroke crank and stock blocks. It causes piston skirt issues. I personally had a 408 that was a factory block that was bored out and a 4" stroke. I was N/A when I did it and cubes mean a little more. Since you will have the blower you can keep the better geometry, have less pistons issues and still make as much power as you want. This is also why you see 370's being a popular engine with boost. Its a 6.0 block bored a little with a stock stroke.
CorvetteBrent (08-09-2018)
For the cost of a new LS3 stroker I think the workshop can rebuilt my current LS1 and make it stroker 383, that will save me half the cost and I can go with smaller pulley and make up the difference.
My current LS1 with 4.25" pulley the car is making 636 rwhp on Mustang Dyno that means that if I go with a 3.4" I can get maybe another 200 rwhp
what you guys think ?
Or is that just way more expense/trouble than it's worth?
It'd be 364ci, or 370 with a 4.030 bore.
364ci is 5% less displacement than 383, but with an 8% shorter stroke... so could you just rev it 8% higher for the win?
Related question: Is it practical to re-sleeve an LS1 / LS6 to get a 4" bore?
It really is a bit of a random thread though..going from the extreme of a 510LSX..which really is extreme, to re-using his own LS1 block ? LS1 block, certainly with stock sleeves is probably about the worst of all options for 1khp. Although that 1k goal maybe seems to have dropped to the 800 range ?
Really...it's all over the place nevermind the price difference between a full 510 LSX and a stock LS1 lol.
So what are the goals, what is the budget ?
My budget is $5k in the short block, $2.6k in heads and 35 hours of labor, that is like $12k more or less.
My goals is to reused most of my current parts as they are new and I do not want to build everything again, this includes
Fast 102mm Intake
Fast Fuwl Rail
Fast 60 lbs injectors
High Volume Oil Pump
Water Pump
Camshaft
I have msd 2351 installed
I have water / methanol kit installed
I wish a reliability 1000 rwhp engine build with parts to last, pulling in between 800-1000 rwhp with boost. This is enough for now.
Fast 102mm Intake
Fast Fuwl Rail
Water Pump
Camshaft
I feel like a forged piston/rod LS2/3/9 will easily do that for you. I have a piston and rod LS2 with AFR 205 heads and I'm shooting for 1000whp.
Fast 102mm Intake
Fast Fuwl Rail
Water Pump
Camshaft
Fast 102mm Intake
Fast Fuwl Rail
Water Pump
Camshaft
LS3 is a better stronger block and lets you see a larger engine without the need for a longer stroke. ( LSA/LS9 would be better but add substantial cost )
Some CA625 studs for insurance or go 1/2" studs. But many get away without either and just regular ARP studs.
Some will say you dont need to spend a lot on heads...I do feel good heads are a good investment, aftermarket with stronger castings etc. But there's no question even basic OEM heads can make a lot of power with ease with a little porting/work
Most will dislike that intake for fear of it blowing apart under boost.
60lb injectors are not taking you to 1000hp....not a chance.
Camshaft...will depend on specs how good/bad it might be.
You will need a proper fuel system for 1000hp.
How much boost is safe for a Fast 102?
FAST probably say 30psi...
Most users who've broken them will say nowhere near that lol
I dont think there is a simple answer...but they do carry risk, more so than other intakes.
Fast 102mm Intake
Fast Fuwl Rail
Water Pump
Camshaft
Fast 102mm Intake
Fast Fuwl Rail
Water Pump
Camshaft
That will hold more than 1000rwhp
https://www.facebook.com/pg/thompson...=page_internal
#35
