3 bar map sensor - what brand
Old Jul 14, 2018 | 09:40 PM
patrick4588's Avatar
patrick4588
Default 3 bar map sensor - what brand
2002 z06. if i get the GM# 12223861 3bar MAP, do i need an adapter harness? If so, does the MSD 2313 3 bar map need it as well? Summit is only an hour away and they have both sensors. but the harness is backordered until mid august. So ideally... Id like to get the one that will get the car running tomorrow.
Old Jul 14, 2018 | 10:00 PM
patrick4588
alternatively, i see there is a 3.3 bar from a duramax? does that plug and play? open to other suggestions if anything tried and works
Old Jul 14, 2018 | 10:08 PM
patrick4588
is AC Delco 213-4658 plug n play? If i can somehow replace it without pulling the intake off thatd make my day too but seems unlikely
Old Jul 14, 2018 | 11:23 PM
Podium's Avatar
Podium
I use EFI source. Its plug and play and works well so far.
Old Jul 15, 2018 | 04:57 AM
romandian's Avatar
romandian
interesting, but out of stock, it sais.
Old Jul 15, 2018 | 09:55 AM
patrick4588
After reading some threads i ordered the duramax sensor. Appears to be plug n play and 3.3 bar
Old Jul 15, 2018 | 01:13 PM
junk c5's Avatar
junk c5
I’m using an MSD 3 bar sensor. I believe I got the adapter harness through Casper’s . I’ll look when I get home.
Old Jul 30, 2018 | 06:40 PM
FourG63 97GST's Avatar
FourG63 97GST
who's tuning your car? ask them which to get. it come down to that, and the data there's able to get plug into the pcm.
To 3 bar map sensor - what brand
