Rev limiter
Old Aug 1, 2018 | 05:11 AM
CorvetteC5Norway's Avatar
CorvetteC5Norway
Default Rev limiter
LS1 stock internals with NOVI 1500 kit, MN6. Where would you tune you're rev limiter to kick in? In the current tune it's set to 6000 rpm's (where it makes aprox 10 psi with stock exhaust except axleback), but I will probably have the car retuned this winter since my (AEM) afr shows 10,5-11 through the revs...
Old Aug 1, 2018 | 08:19 AM
itsslow98's Avatar
itsslow98
I'd see where the power peaks and make it 500rpm after. My limit would be 6800 but its if your valvetrain can handle that.
