Nitrous Engine Build
Old Aug 18, 2018 | 12:08 PM
mykream's Avatar
mykream
Default Nitrous Engine Build
So I plan on spraying the LS6 in stock form the rest of this season. After that, I will pull the engine to build it up.
So far this is my list for components, the car will see at most a 250 wet.
Pistons:
Diamond 11526-R1 (3.905, 3.622, -10cc)
Rods:
Callies CSC6125DS2A2AH
Heads:
TFS 220, powdered metal guide, 68cc
Current cam in the car is a BTR Stage 4 LS3 cam. I feel that I will most likely keep this cam as it performs well now, but I think it will really shine in the new setup.
Doing a quick calculator, this setup should put the car with an .051 HG at around 11.24:1. Would like to see around 11.5-11.7, most likely will just need to accomplish that with a 66cc chamber on the heads.
Keeping the stock crank, or at least intend to. I see no reason why I would need a new one.
Car will keep the Fast 102 on it and probably keep the LS2 TB.
Just would like thoughts on the setup.
Old Aug 25, 2018 | 03:31 PM
Water_Walker's Avatar
Water_Walker
What are the plans for rings?
