Help - blowing fuse on Racetronix harness
Finished up my single turbo build recently. Currently putting break in miles on it so I have been driving it gingerly. It’s been running pretty well for a few weeks now until it left me stranded. I discovered a blow fuse in the racetronix harness. Replaced the fuse and it blew again right away. Any guesses what I should look for?
thanks,
Sean
thanks,
Sean
definitely sounds like a short somewhere in the circuit. I would trace the harness on where you have it routed specifically and make sure its not pinched or frayed anywhere...
You definitely have a wiring issue. The Walboro should not be pulling more than 20A.
