C5 Z06 custom rear mount twin turbo build
I did my rear mount without cutting the trunk out. I used a T4 Masterpower T70. If I had to do it again, I’d do a custom T4 80mm forced inductions turbo, non intercooled, E85 combo. Here’s a short video of me messing around. Car made 575 RWHP.
Seems like way more work and time when you can throw a blower on the car and hit the power goal with ease. My 04Z its a Novi 2000, with only headers and meth is at 600 to the wheels at 6psi.. Installed it 11 years ago, never a single issue, and just finally changed the original belt.
Thats the whole point!! More.work makes me happy!
Hey Georgies,
Do your research on routing the twin pipes through the rockers, I've read countlss threads about how hard it can be to get the charge pipes through the rockers few was easy few could not period. Some cars have more obstruction as in glue/adhesive in the rockers. I have a very large Lloyd's trunk mat that most people will not know I cut the trunk out.
USED PARTS.. only used parts I'm going with are the turbowerx pump from JunkC5 I trust him and a used precision wastegate, have all the parts, box, papers and I trust the guy as well. I did buy a Vs racing turbo from Viren. China turbo. Prob never buy a name brand turbo. China turbo quality is up there nowadays. Seen issues with name brands then you rebuild.
good luck
Jason from San Antonio
good luck
.......be careful what you wish for.
Maybe your project will turn out great, we don't really know your experience level so we can't really judge yet. I applaud you for wanting to do it yourself, just seriously be careful what you wish for man. I've see many a person get way way over their head very quickly, spend a crap ton more money than needed while at the same time being exceptionally frustrated with sub par performance.
We are here to help, even if we seem negative at times. Just trying to ensure you get the best bang for your buck and don't end up hating yourself and the car after all the work is "complete."
- Travis
- Travis
That being said, I don't blame you for not wanting to cute the tub up.
- Travis
you will be happy with the ttix kit very good quality Huron setup looks nice too. I'm not a fan of the rear mount for other than packaging. You want the turbos closer to the exh valves
rear mounts can work, but I'm not a fan.
#35
So what are you gonna build now?
with all the research I've done, I would not do twin .91 at max .61 for me and I think those turbos too big. I've seen a single s369 make 650ish rw.
#38
I would run twin 55-60mm turbos with around .61 at
call Viren at vs racing if you want quaity China turbo or the guys at forced induction solutions if you wanna spend $$
#39
I would be looking at something more like a 5858 or 5862 for a twin setup, thats like a pair of 600hp turbos. Keep in mind AR is relative to the flange size, so a T4 .64 is not the same as a T3 .64... just important details to keep in mind when shopping. I would honestly opt for T3 / smaller AR so you get more mid range power and top end shouldnt be a problem unless you really start pushing it. All depends on your goals and how much potential you want to leave on the table for later potentially. The tendency I think for many is to go really big, which looks cool but you give up a lot of low and mid range power and generally makes the setup not responsive.
#40
buddy of mine is going from rear single turbo to a front mount stand up the radiator and he thinks he needs 3" hot side for big numbers and I'm like bro 2.25-2.5 will be perfect. But he also thinks his 3" single rear turbo is perfect size and doesn't know why it spools slow plus it is not wrapped
