Ms109
Old Jan 8, 2019 | 10:27 PM
jattz06's Avatar
jattz06
Default Ms109
whos running ms109? Pros and cons?
Old Jan 8, 2019 | 10:49 PM
StingrayRebel's Avatar
StingrayRebel
do you have enough fuel system for e85?... it's cheap and from what I've gathered it makes more power than the expensive race fuels
Old Jan 8, 2019 | 11:05 PM
jattz06's Avatar
jattz06
I don’t think my current fuel system will handle e and I don’t have any local stations near me
Old Jan 9, 2019 | 11:28 AM
Turbo-Geist's Avatar
Turbo-Geist
2017 C5 of Year Finalist
Pros: It burns clean and you can make good power on it.
Cons: It has a higher cost so I wouldn't want to be cruising around with it in the tank or driving to and from the track.
Do you have a methanol injection system?
Old Jan 9, 2019 | 11:43 AM
jattz06's Avatar
jattz06
thanks and yes I have meth on the car.. right now it’s 91+meth I’m going to see what I would have to change on my current fuel system to run ignite. I currently have the a&a single aux pump and id1000 injectors
Old Jan 10, 2019 | 10:39 AM
TX Z06 02's Avatar
TX Z06 02
I put 5 gallons of MS109 in with 3/8 tank 93 octane. I only did it because I am troubleshooting KR with the new engine and wanted to see if the knock was real or false.
At $10/gallon for MS109, I will continue forward with my original plans of E85 conversion ($1.77/gallon) once I get this new engine dialed in.
Old Jan 10, 2019 | 10:52 AM
jattz06's Avatar
jattz06
where are you getting ms109 at $10 a gallon?
Old Jan 10, 2019 | 10:55 AM
TX Z06 02's Avatar
TX Z06 02
I live about 30 minutes from Cresson, where the Texaco at the entrance to Motorsports Ranch has VP racing fuels at the pump. They had MS109, and 2 others (1 leaded, 1 unleaded).
Old Jan 10, 2019 | 12:33 PM
jattz06's Avatar
jattz06
wow best price I can find around me is $18 a gallon.. I do live in Ca so that will explain that
To Ms109
