LSA supercharger on a ls1
Received 4,169 Likes
It's most definitely not impossible. I'll leave it at that.
No, it will not just bolt right on there.
If you're not prepared to do all 100% custom work, leave it alone.
Received 19,435 Likes
'20-'21-'22-'23-'24
Moved to C5 Forced Induction/Nitrous section.
The LSA Blower base itself will hit the cowl. If you dont mind cutting it up you can fit it as well as figuring out the hood. In this picture the cradle is lowered 1/4" and the blower hitting the cowl still needed to go back about 1/4" to line up the bolt holes. It was a test fit for giggles
LSA test fit on a C5 with lowered cradle
https://www.corvetteforum.com/forums...manual-c5.html
There is a thread 7 threads down from yours discussing this exact topic...
nickalltogether (03-01-2019)
nickalltogether (03-11-2019)
