T-stat??
Old Apr 17, 2019 | 02:12 PM
Smoken1's Avatar
Smoken1
Default T-stat??
What temp T-stat should I run, my temps in Oregon Might hit 100 degrees in the summer for a few days...
Old Apr 17, 2019 | 02:33 PM
Smoken1's Avatar
Smoken1
If this helps I do have the Dewitt's radiator and the dual Spal fans going in
Old Apr 17, 2019 | 03:10 PM
aaronc7's Avatar
aaronc7
stock. a lower temp thermostat will generally just make the car take longer to warm up.
Old Apr 17, 2019 | 03:19 PM
Smoken1's Avatar
Smoken1
Thanks, that's what I thinking also due to the lower temps over here
Old Apr 17, 2019 | 03:25 PM
aaronc7's Avatar
aaronc7
I run stock and water temps stay right around 190-200 based on my PCM fan settings. On the track (road course) temps never got above 210 for me.. and that's in Florida/Lousianna in the summer, so its quite warm. I have the Dewitts radiator as well. The upgrade is the radiator, the thermostat is not some magical fix....IMO.
Old Apr 17, 2019 | 03:26 PM
aaronc7's Avatar
aaronc7
BTW I have a brand new OEM t stat waiting to on the car. For fun I put it in a pot of boiling water. At my elevation, boiling temp is around 200-205F. And at the temperature, the thing was fully open. So unless you want to run something colder than that, no reason to change it.
Old Apr 17, 2019 | 03:50 PM
Smoken1's Avatar
Smoken1
Okay. I have a new stock one sitting here I will put in a pan and see where I am
To T-stat??
