Vararam intake plenum to intercooler
Old Nov 13, 2019 | 02:10 PM
  #61
aaronc7's Avatar
aaronc7
I store my boost in a lock box located in the trunk
Old Nov 13, 2019 | 03:03 PM
  #62
Speedy007's Avatar
Speedy007
How hard is it? Is it super quiet?
Old Nov 13, 2019 | 05:08 PM
  #63
Turpid porpoise's Avatar
Turpid porpoise
Originally Posted by Speedy007
Wrong the AA rubber nylon pipe that I cut is slightly curved nothing like that 45 degree bend. I actually had to push the intake flat to slide into the couplers it’s 35 plus degrees straighter than before. I’ll look for my protractor.
Think about what you are saying.... The tube connects the same two points together..... It must have the same degree of bend or else it would be sticking up in the air. The bend may be 22.5* at the fore flange and 22.5* at the aft flange but it is still 45* worth of bends....
20+25=45. 22.5+22.5=45. 0 does not equal 45.
Old Nov 13, 2019 | 05:26 PM
  #64
Podium's Avatar
Podium
Its obvious you dont know how a protractor works.
Old Nov 13, 2019 | 05:30 PM
  #65
Speedy007's Avatar
Speedy007
Any bend is really off the the intercooler going up approximately 1 inch the next curve is seen on the intake.the formation in the supercharged pipe in the kit doesn’t any bend from the top of the intercooler to maf..the intake mostly eats the curve from the aluminum gadget on the entering and exiting ports what goes up must come down.
Any the intake says.....Finally more air. By the way I no longer can smell my cat burning up. Somethings obviously flowing better.
I saw intake temps reduce up to 10 degrees during acceleration !
Old Nov 13, 2019 | 05:52 PM
  #66
Turpid porpoise
Was it possibly 10* colder out today?
Old Nov 13, 2019 | 06:24 PM
  #67
Podium's Avatar
Podium
Old Nov 13, 2019 | 06:38 PM
  #68
Speedy007's Avatar
Speedy007
The iat sensor was spot with the weather dropping from 77 to 67
Old Nov 13, 2019 | 06:40 PM
  #69
Speedy007's Avatar
Speedy007
How much boost is your v3 spooling?
Old Nov 13, 2019 | 06:52 PM
  #70
Podium's Avatar
Podium
17.5. Its higher though, the 3bar map isnt calibrated correctly in the Haltech. it read about 90 KOEO. Should be around 101 in MN at the time of reading.
Old Nov 13, 2019 | 06:56 PM
  #71
Speedy007's Avatar
Speedy007
I thought 3 bars went up to 125 kph and beyond to 145 ish
I have one let me check the specs on it ! Doesn’t the detail much other than max 43.5 psi -40to 260 operational temperature. Able read 10-90%of total manifold pressure
Old Nov 13, 2019 | 06:58 PM
  #72
Podium's Avatar
Podium
They are, the calibration in the Haltech isn’t correct. I use data from the manufacturer. Next season I’m just going to use the built in 5 bar in the haltech and not worry about the calibrations
Old Nov 21, 2019 | 07:17 PM
  #73
aaronc7's Avatar
aaronc7
bump
Old Nov 21, 2019 | 08:11 PM
  #74
Podium's Avatar
Podium
Old Nov 21, 2019 | 08:55 PM
  #75
Speedy007's Avatar
Speedy007
It is working been working out just fine All the lower end gearing has come back bet I picked up a noticeable 40 horses roughly
Old Nov 21, 2019 | 11:16 PM
  #76
silver408z's Avatar
silver408z
Old Nov 22, 2019 | 12:36 AM
  #77
Speedy007's Avatar
Speedy007
Originally Posted by silver408z
To Vararam intake plenum to intercooler
Old Nov 22, 2019 | 07:02 AM
  #78
Turpid porpoise
By swapping from a metal tube to a plastic tube? You can't be serious....
Old Nov 22, 2019 | 07:20 AM
  #79
Podium's Avatar
Podium
Its obvious the plastic flattened air bridge forms the air better than the round, aluminum tube which creates more power. Science!
Old Nov 22, 2019 | 07:54 AM
  #80
Turpid porpoise
Imagine how much power you could get through something shaped like this!!
