Vararam intake plenum to intercooler
Old Nov 22, 2019 | 12:33 PM
  #81
Speedy007's Avatar
Speedy007
The intake looks nothing like your sippy cup staw! If you research the design of the plenum then you will see how the design works. I’m sure vara didn’t spend millions of dollars and time molding and test for the product to in effective. It is obviously a 4inch inlet and outlet hold more air for starters. The inside creates a velocity stack . If there was any bad to guess the s/c is prob actually working now. As I was trying to explain the car was a little dud after the head swap in the low end. But now it’s back from a simple plenum change. Btw that gurgle has come back on the exhaust note. I’ve noticed some good pops on the start up has come back the little things that make people’s head go wtf is in that!
Old Nov 22, 2019 | 12:49 PM
  #82
Turpid porpoise's Avatar
Turpid porpoise
Vararam did not spend millions of dollars testing it. They also didn't design it for your application, it is designed to be used in conjunction with their intake ducts. You don't need a velocity stack in a charge pipe, you need it before the compressor, if at all.
I'm done with this thread. It is quite clear you have zero intention to listen to what others have to say and very little knowledge about airflow.
Old Nov 22, 2019 | 01:22 PM
  #83
StingrayRebel's Avatar
StingrayRebel
Originally Posted by Turpid porpoise
By swapping from a metal tube to a plastic tube? You can't be serious....
Old Nov 22, 2019 | 04:00 PM
  #84
Speedy007's Avatar
Speedy007
Its clear your mr.Right and everyone else is Mr.Wrong. Yes and look it up the plenum was designed for the c5 both for n/a and supercharged applications it’s funny how people like to blab but do no research ! Have you even attempted to put one on? I thought not thank you goodbye
Old Nov 22, 2019 | 05:07 PM
  #85
heggsc5's Avatar
heggsc5
Just came across this deal in the classifieds, guys. $100 for 40 horses! Act quick before he buys it and daisy chains them for 80 horses!
https://www.corvetteforum.com/forums...torch-red.html
Old Nov 22, 2019 | 08:56 PM
  #86
Speedy007's Avatar
Speedy007
I buy everything I’ve put in the car new so others don’t have to worry about me jumping on that plus I’ve got one already why have 2 ?
Old Nov 22, 2019 | 09:50 PM
  #87
Speedy007's Avatar
Speedy007
Plastic tubes also don’t create as much heat soak as with a metal tube but then again what do I know right you can’t be serious. Q-TIP . As in don’t take it personally I am always open to what people have to say and thanks for being part of my threads all of
you! Cheers!
https://www.corvetteforum.com/forums...-or-turbo.html
Old Nov 22, 2019 | 10:25 PM
  #88
Speedy007's Avatar
Speedy007
Imagine how much power you could get through something shaped like this!!
If you were to measure the space of which you have in the 3in ch diameter tube for air to flow. Also measure the space you have with a vara you would have a fact positive result the vararam is holding more then the tube.I could also bet velocity is near the same bxt the two pipe judging my maf sensors spikes. How smooth the airs travel is different subject here. I believe what ever vararam post I’m a firm believer had the plenum and intake on before this build the car ran better then my friends c6 base model. How much more do I need to sort log details and power results ?
Your are right about the velocity stack there’s no need to have it inserted. Somewhere along the way I forgot to relay that.
Old Nov 22, 2019 | 11:14 PM
  #89
ascastil's Avatar
ascastil
Well at least this thread is civil and hasn't turned into another chit box thread.
Old Dec 5, 2019 | 06:21 PM
  #90
Speedy007's Avatar
Speedy007
WE CANT MAKE IT SPOOOL FASTER. ! However you are able to the space in bxt for a draw which some are just no able to comprehend! Less lag more air at a better time ratio. This thing is virtually helping the impeller which makes the air turn spin whatever your choice of word is with less resistance! Leading again to more air to its destination sooner. Drafting its used in nascar the same theory could be placed in how your vehicle air flow to draw air up or be carried!
Old Dec 6, 2019 | 07:05 AM
  #91
Turpid porpoise
Old Dec 6, 2019 | 12:49 PM
  #92
Speedy007's Avatar
Speedy007
Anyways next time I have some free time to get my hands a little dirty. I have a 100mm maf going on. This as well should increase flow and allow for more fuel to used and a power result should happen as well. The idea of reverting back to a maf tune is kicking around.
Old Dec 6, 2019 | 01:04 PM
  #93
aaronc7's Avatar
aaronc7
Not happy with speed density tune?
Old Dec 6, 2019 | 01:16 PM
  #94
Speedy007's Avatar
Speedy007
Well I am and I am not. Here’s why. After I’ve unhooked the battery the maf tune will be enabled until of course it reaches its P0103 high frequency to much air . But during the small time I am able to stay within the hertz before it spikes out the engine does seem to perform with a noticeable power advantage over the sd tune. That’s the feel I’m getting. Also changing to a 100+ octane gas also made car run smoother.
Old Dec 6, 2019 | 01:37 PM
  #95
aaronc7's Avatar
aaronc7
So you're just maxing out the MAF and not hitting the airflow limit of 512 g/s or 67 lb/min or whatever? I'm pretty happy with my SD tune but MAF was definitely easier and woulda kept it if easily done on my case. SD forced me to do a good VE table finally lol.
Old Dec 6, 2019 | 03:06 PM
  #96
Speedy007's Avatar
Speedy007
[QUOTE=aaronc7;1600606829]So you're just maxing out the MAF and not hitting the airflow limit of 512 g/s or 67 lb/min or whatever? I'm pretty happy with my SD tune but MAF was definitely easier and woulda kept it if easily done on my case. SD forced me to do a good VE table finally lol.[/
I will post up on my tuning Thread ! But maf exceeded its limits at 10-15% tp !
Old Dec 14, 2019 | 12:34 PM
  #97
jattz06's Avatar
jattz06
the good ol chit box
To Vararam intake plenum to intercooler
Old Dec 15, 2019 | 07:54 PM
  #98
Speedy007's Avatar
Speedy007
I picked up over 4mpg on the highway trips with the changes! Incredible 38 to 42.2 highway!
Old Dec 15, 2019 | 09:50 PM
  #99
aaronc7's Avatar
aaronc7
You should make/post some more of your youtube vids
Old Dec 20, 2019 | 12:40 PM
  #100
Speedy007's Avatar
Speedy007
How many of y’all actually watched them?
