Question about meth pump?
Old Dec 30, 2020 | 08:20 AM
04zjimc's Avatar
04zjimc
Default Question about meth pump?
Guys with meth pumps do they go bad from sitting all winter? I didn't drain some leftover meth out of the tank.. thanks
Old Dec 30, 2020 | 09:04 AM
SmoothFRC's Avatar
SmoothFRC
If you’re running pure m1, yes- the methanol will eat the seals and cause the pumps to leak.
I’m finding I send mine off for a rebuild about once every two years.
Old Dec 30, 2020 | 12:06 PM
04zjimc's Avatar
04zjimc
Thanks! Yes I am. Guess I good drain whatever is left.. its a brand new pump.
Old Dec 31, 2020 | 12:13 PM
Cutlassmaster's Avatar
Cutlassmaster
I just had Julio rebuild my original last week. The new one from just under 2 years ago started leaking at Thanksgiving. I'm gonna send that one out now.
Old Jan 1, 2021 | 09:50 AM
Rkreigh's Avatar
Rkreigh
when I ran an alchy BB chevy at the dig (ron's flying toilet mechanical injection), I had to pickle the system and run pump gas though it
try that with maybe some marvel mystery oil and just use the test button and vent the nozzles to a bucket to pickle the pump before retiring for the winter and it might last longer
I worry about that too, make sure to ask julio about what he might recommend to preserve the system when not being used. best thing to do is keep using it. alchy won't freeze.
Old Jan 4, 2021 | 09:04 AM
LPDesRoche's Avatar
LPDesRoche
Just look at the pump as a wear item in the system. I'm pretty sure no matter what you do, the life span is somewhere around 2-3 yrs. I've done mine both ways (drained, not drained). It's a relatively cheap and easy fix.
To Question about meth pump?
