So I decided to go with the Holley Terminator X Max (550-926) and I was curious if anyone that has experience with installing this kit could throw me some tips before I start the installation ? I’ve already figured out I need an alternator harness, 2 pressure sensors and a couple adapters & fittings. Also, with our rear mounted transmission, I already foresee the need for a longer transmission wiring harness. Any help or suggestions would be great. Thx.
do you have a diagram, or something to go off of showing which wires on the OEM harness need to be separated to retain the ignition system by chance?
I am in the process of doing the Terminator X max, and I’d like to retain the alternator wiring, and stock ignition system from the harness I removed. Any assistance or tips would be greatly appreciated.
