LSA crank
Old Feb 22, 2021 | 11:32 AM
Rkreigh's Avatar
Rkreigh
Default LSA crank
I'm thinking about using a LSA crank in an automatic 4L65E c5 vette
I know the LSA has an 8 bolt flexplate, I'm curious if the driveshaft snout clamp will mate up.
the lsa 8 bolt sfi flexplates cost as much as the durn crank!! (I got a good deal)
any problems going this route? The stock LSA forged crank is a beauty!!
if needed I can use this crank in a different engine if this is a hassle.
Old Feb 22, 2021 | 07:53 PM
douniasg's Avatar
douniasg
Hey bud I just went through this with my c7 which has a 8 bolt crank. I purchased a rm-998 quicktime flexplate. That flex plate has a 6 bolt pattern for the spline coupler. I ordered the rpm blillet cone. Most people don't need the billet one unless you are serious drag racing.
Old Feb 22, 2021 | 07:56 PM
douniasg's Avatar
douniasg
The 6 bolt snout will not mate. You will either need a stock c7 flex plate with snout or order the quicktime to use your 6 bolt one.
Old Feb 23, 2021 | 06:13 AM
Rkreigh's Avatar
Rkreigh
thanks so much for the help. This car will get beat on so I better not punk out and get the good stuff
I'll check this stuff out and see what I can swing
To LSA crank
