Bypass Valve
Old Mar 29, 2021 | 01:01 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Default Bypass Valve
My engine is a 402 with PRC 225s and a jam cam and will be running a V3Ti. It is likely to be comfortably north of the 600hp limit stated by A&A on their site for their stock 38mm turbosmart BOV / bypass.
If this were a turbo setup and a proper BOV, I'd be all about going with a sharp / loud piece. On SC setups the intent is the same as far as relieving pressure from the charge system, but it happens when you let off the boost and need to evacuate pressure ahead of the IC and you end up with a long flatulent whooosh noise instead.
I don't think I really want a loud flatulent bypass valve.
Is there a trick to go big but keep it quiet?
Also, A&A sells the Big Bubba but as a kit for $430 where I need none of the associated piping since I already have it. Is there any internal difference to their version of the Big Bubba? Otherwise, it can be had for about $300.
Am I barking up the right tree seeking the Turbosmart? Should I look at Tial or others? I imagine it doesn't make much difference but maybe I would be suprised.
Old Mar 29, 2021 | 02:16 PM
chris308's Avatar
chris308
I think you could get a 50mm TiAL recirculating bov with the SC spring (drk green i believe) and just pipe the swoosh swooshies back into the intake.
Old Mar 29, 2021 | 02:42 PM
heggsc5's Avatar
heggsc5
The Big Bubba is no different than the 38mm, it's just larger so you'll need the t-pipe that taps into your plumbing. You can definitely turn the Big Bubba into a recirculating valve with one simple hose and some creative routing. I'm running the Big Bubba with the filter on and it's definitely louder than the 38mm was with no filter, but it's nothing crazy or obnoxious. I wouldn't describe it as a flatulent sound, it's more like a heavy exhale sound. I've seen it described as a street sweeper and I feel that's pretty accurate.
Old Apr 8, 2021 | 08:21 AM
KT35's Avatar
KT35
I run the 50mm no issues. The 50 is not loud and mounts in the same position.
KT
Old Apr 24, 2021 | 04:33 PM
_zebra's Avatar
_zebra
factory turbo systems plumb the BOV outlet back into the intake for that very purpose.
To Bypass Valve
