Running lean in Boost, Help
Old Sep 20, 2021 | 02:14 AM
  #41
stevieturbo's Avatar
stevieturbo
So it's even leaner on boost and you think that's a positive result ?
At 12.2 you're gonna blow **** up.
Seriously, get the car to a competent person.
Old Sep 20, 2021 | 05:18 PM
  #42
FourG63 97GST's Avatar
FourG63 97GST
so a boost leak at the intake made it run lean? that's not working out in my head, if the air is already metered at the maf, and leaking boost at the manifold, the AFR would be rich, as it's providing fueling for the air that's already metered at the maf, I'm assuming the car isn't on speed density, since it only has a 1 bar map sensor. someone tell me if I'm wrong, I'm not familiar with boosted MAF cars.
Old Sep 20, 2021 | 06:51 PM
  #43
corvet786c's Avatar
corvet786c
You must not of read what I already stated , The AFR its richer from 13.2 to 11.9, Yes Read next time. Car has already been tuned by a competant person, it runs great
Old Sep 20, 2021 | 06:53 PM
  #44
corvet786c's Avatar
corvet786c
Its called a gasket manifold leak, there was oil all in their with it already being compromised. I added new gaskets problem solved. This is especially a culprit on Fast intakes.
Old Sep 21, 2021 | 11:03 AM
  #45
FourG63 97GST
ok, gasket manifold leak, boost leak, same thing. I was just trying to understand why. technically with it changes, should be getting more air into the motor, making it leaner, I'm wondering what other tables you have that's adjusting fueling. The oil getting into the intake manifold, is from your PCV/breather system. it'll eventually be oily in there again, you just wont see it from the outside now if the original gasket was that bad.
also, I assume you datalogging, whats the max KPA are you seeing from the MAP sensor? and how much boost are you running
Old Sep 21, 2021 | 12:53 PM
  #46
stevieturbo
This thread and your plethora of problems and need for help, would seem to suggest otherwise.
Old Sep 21, 2021 | 06:43 PM
  #47
corvet786c's Avatar
corvet786c
105 KPA and about 10lbs. I do have a PVC LS6 system but there was some oil on the bottom of the gasket. The gaskets were soft and leaking, it could not hold my boost. I just replaced them and problem gone Thanks Chris
Old Sep 21, 2021 | 06:52 PM
  #48
corvet786c's Avatar
corvet786c
If your interested in my logs they are here
https://forum.hptuners.com/showthrea...ns-Logs-Thanks
Old Sep 21, 2021 | 06:58 PM
  #49
corvet786c's Avatar
corvet786c
Thats your opinion. The cars is fine Thanks
Old Sep 21, 2021 | 10:48 PM
  #50
TimbrSS's Avatar
TimbrSS
Since I am using a stock1 bar there is a strap inside that stretches and measures pressure each and everytime past 14.6 psi, To my understanding, well keeping this up, once that strap stretches to much it breaks and the Map is no good. Yes Ideally I should of been tuned for a 2 bar, but wasnt. This morning I put the old MAF on and forget it, car was stumpling.
I knew right away when I started reading this thread it was probably just a stretched map strap.... see it all the time.
Old Nov 12, 2021 | 01:03 PM
  #51
corvet786c's Avatar
corvet786c
Well for the record after all this time, I finally figured out what was wrong, Not the Wideband or AEM Guage. The updated Delphi MAF was the problem, Mine was tuned with old part number 25168491. So I bought one on ebay all, I had to do was unhook the battery for 30 min for the computer to relearn MAF. Looking at the data log graphs, O2's are were they should be and AFR reading 10.5 to 11.7 under boost. Now I am battling knock.
Old Nov 15, 2021 | 08:53 AM
  #52
Rkreigh's Avatar
Rkreigh
look at pulling timing and doing a "hook test" You slowly advance timing until the engine doesn't make more power but also stays far away from detonation
save that piston!!! No build will survive the pounding from detonation.
Old Nov 23, 2021 | 04:42 PM
  #53
corvet786c's Avatar
corvet786c
Yeah, I am getting retuned and going speed density, should take care of my problems.
