Running lean in Boost, Help
Old Sep 4, 2021 | 08:53 PM
corvet786c's Avatar
corvet786c
Default Need the Experts, Running lean in Boost, Help
Ok, car is a 2002 procharged Fast 102 headers A4. Had my issues resolved before which was the Map sensor, Now I have a new map sensor(3 Bar), new o2's and a new MAF, The car runs alot better, just going into boost a/f guage read the dump at 10.5 then goes to 11.5, 12.8, 13.2, as the rpms increase.
When I worked on the car a few days ago, I removed the headers and Fast 102 intake , but torqued it properly,
Any suggestions, Ideas Thanks.
I believe it could be the MAP sensor location fitment, not properly sealing, I am getting the RTV on it now and letting it dry over night? Will check tomorrow
Old Sep 5, 2021 | 10:57 AM
stevieturbo's Avatar
stevieturbo
Has it ever been tuned correctly for all the work that has been done ?
You cannot just fit random parts and hope for the best.
Old Sep 5, 2021 | 11:52 AM
FourG63 97GST's Avatar
FourG63 97GST
check voltage throughout the pull, preferably the voltage at the pump
Old Sep 5, 2021 | 06:32 PM
corvet786c's Avatar
corvet786c
Uh Yes, Before those parts failed and left me stranded, it was tuned with HP tuners WOT was from 10.5 to 11.5
Old Sep 5, 2021 | 06:37 PM
corvet786c's Avatar
corvet786c
Not sure how to check it but I am using a boost a pump and the fuel pressure looks pretty good around 56-57 psi, The Fuse has not blown either.
Also I double checked the header bolts this afternoon and the passenger side bolt was torqued, but I went a quarter turn and now its stripped. So not sure if that bolt was the issue, running a lean condition
I sealed the MAP sensor on the fast 102 hopefully no leaks.
I did a few pulls today on an open road and it seemed that the 11.5 AFR was holding on my guage to about 4500 rpms, but then started going lean to 13.2 under boost. Unless its giving me a false reading
But I got to get that header bolt tapped, before I do another WOT pull. I hate pulling the header. Yikes.
Old Sep 6, 2021 | 11:58 AM
FourG63 97GST
there's some backstory I don't get. what problem were you chasing before you started changing sensors, is the lean issue a new problem? if not, at what point in you changing parts, did the issue appear. if you changed stuff than can affect the tune and airflow. it being lean now isn't farfetched.
if you don't have a voltmeter, at minimum you can looks at the battery voltage on the cluster. also having good fuel pressure at idle, doesn't mean it'll be good at WOT. you basically need more data to diagnose this properly
Old Sep 6, 2021 | 12:16 PM
brentsz06's Avatar
brentsz06
take your car back to your tuner. make a pull and have him take a look. if hes worth his money he will be able to see whats not working correctly to cause a lean condition.
Old Sep 6, 2021 | 04:51 PM
corvet786c's Avatar
corvet786c
I went WOT and the car just shut down, would start but not idle, it would cut off, So they diagnosed it as a bad MAF and a bad MAP, saying I need a 3 bar., Also I put new O2's in it, fuel pressure good, just got back from a drive.
So when I hit it the AFR Guage goes to 10.0 then rises to about 13.0 at about 4800 rpms and I just shut it down, Dont know what else to do anymore.
My question is just changing MAP, MAF or O2 sensors affect the tune if they were the same part number? I didnt think it would?
Old Sep 6, 2021 | 04:54 PM
stevieturbo
Sounds like BS. Find a competent person to diagnose and fix the problem, and ensure tuning is correct for all the parts you've fired at it.
Old Sep 6, 2021 | 05:19 PM
corvet786c's Avatar
corvet786c
ok here is the original map sensor with the tune, IS this a 1 or 3 bar map? This was actually epoxied to the intake no leaks at all, 11.5 all the way up, Not so much now.
Old Sep 6, 2021 | 05:50 PM
stevieturbo
That appears to be a stock 1 bar map sensor.
You cannot just randomly change it for any other sensor unless you are also going to re-program the ecu for whatever sensor you are fitting.
Old Sep 6, 2021 | 05:59 PM
corvet786c's Avatar
corvet786c
ok great then thats what I need to get then, My car was tuned for a 1 bar, I guess going off the MAF for fuel trims.
This is what is on my car now, not sure what brand it is or if it is a 3 bar?
Old Sep 6, 2021 | 06:10 PM
stevieturbo
no idea what it is, google the numbers to see if anything comes up.
But as the map sensor can be a critical sensor, where possible I would always use genuine OEM parts, not some cheap unknown chinese ***** copy.
Old Sep 6, 2021 | 06:16 PM
corvet786c's Avatar
corvet786c
OK thanks steve then I am going to get one genuine GM.
Old Sep 7, 2021 | 11:15 AM
helga203's Avatar
helga203
OK guys correct me if im wrong, but if u unplug the map it will default to sd, if it does the map is good. Thats a safety if the maf fails.
Old Sep 7, 2021 | 11:19 AM
corvet786c's Avatar
corvet786c
Everything seems to be working better Thanks
Old Sep 7, 2021 | 12:32 PM
KT35's Avatar
KT35
Going from a 1 bar to a 3 bar map sensor will give you issues if you do not adjust for it.
To Running lean in Boost, Help
Old Sep 7, 2021 | 01:51 PM
stevieturbo
if you unplug the MAP sensor, it cannot run SD...because you've unplugged the MAP sensor.
If you unplug the MAF, then it may revert to using MAP more so.
Of course any fallbacks assume whoever has tuned it, has done so to allow that to happen.
If he has the wrong sensors the car/ecu is tuned for....he's screwed either way
Old Sep 7, 2021 | 02:16 PM
corvet786c's Avatar
corvet786c
well like I said, bought an ac delco this morning, the idle seems smoother, did a couple of pulls under boost and AFR drops to 10 then 11 seems to stabalize to around 11.6. I am happy plus he gave me a refund for the MAP sensor he put in.
The photo I posted is a 1 bar pf the original map, then thats what I have now.
Old Sep 7, 2021 | 02:51 PM
KT35's Avatar
KT35
I would find a new tuner!
