C5 Vortech Dyno Results?
Old Jan 13, 2003 | 12:37 AM
MelloYellow's Avatar
MelloYellow
Default Re: C5 Vortech Dyno Results? (Steve'01)
Ahh, ok. You just made a hole into the Aftercooler to Throttle Body 90* elbow hose and put it there?
Old Jan 13, 2003 | 01:04 AM
Steve'01's Avatar
Steve'01
Default Re: C5 Vortech Dyno Results? (MelloYellow)
I used an older style MAT sender from an 89 Vette. It has the same size threads as the oil return line so you can use the drill and tap that came in the Vortech kit. I mounted it into the discharge from the aftercooler. The sender will come with the plug as well (NAPA) so you can spice it into the leads that go to the MAF. I can’t take the credit for finding this; it was Mike at MMS that recommended it. I would think that Vortech must pull extra timing and maybe add extra fuel to make up for the lack of accurate intake air temp on their canned program. :cheers:
Old Jan 13, 2003 | 12:39 PM
carrerarod's Avatar
carrerarod
Carrerarod:
What size and ratio are your 19" rear tires again?
295/30's on 19x11 wheels.....
belt is worse this morning...I think my problems are with the belt. :rolleyes: Should have things resolved shortly...hopefully....
Old Jan 13, 2003 | 07:48 PM
MelloYellow
Default Re: C5 Vortech Dyno Results? (carrerarod)
I'm going to buy some belt dressing shortly. Will be soaking my Goodyear Gatorback in the dressing before install.
Old Jan 18, 2003 | 02:47 PM
roadracnz06's Avatar
roadracnz06
5th Gear
That sounds like a pain! I hope it isn't something you have to do often for weekly maintenance. I enjoy getting in and driving mine without hassle. Are you only doing this to see max numbers on the dyno?
Old Jan 18, 2003 | 06:00 PM
MelloYellow
Default Re: C5 Vortech Dyno Results? (roadracnz06)
It comes in a spray can. Actually, I think I'll leave it alone at first. After I settle into the setup I'll spray it on the belts while moving and see if there is any different in measured boost and how long it lasts for.
Old Jan 19, 2003 | 12:26 AM
opticZ06's Avatar
0opticZ06
Former Vendor
Default Re: C5 Vortech Dyno Results? (av8or3)
Av80r3 I saw your numbers at the dyno today they look nice, at least your car didnt break on the dyno like mine.
Old Jan 19, 2003 | 12:18 PM
av8or3's Avatar
av8or3
Default Re: C5 Vortech Dyno Results? (opticZ06)
Thanks,they were a pleasent suprise. I'm sure after your rebuild you'll have
some tall numbers to brag about. Right now I researching ways to get that
power to the ground (tires/wheels). Good luck on your racing,I enjoy reading
about it. :seeya
Old Jan 20, 2003 | 01:21 AM
MelloYellow
ttt for carrerarod
Old Feb 6, 2003 | 04:41 PM
7LitreC5's Avatar
7LitreC5
I don't have numbers yet but I finally have my car scheduled for tuning. I am getting it done at Xtreme on Feb 24th. I'll post the numbers as soon as I get back from Tempe.
Old Feb 6, 2003 | 10:19 PM
MelloYellow
Default Re: C5 Vortech Dyno Results? (VortechC5)
Cool. Mine is getting installed next week too.
Am prepping LS1Edit as we speak.
Let us know how it works out. Probably 2 weeks before I'll have dyno numbers.
Old Feb 8, 2003 | 01:19 AM
Yano's Avatar
Yano
Nice name change Mark!!!!!! :cheers: :cheers: :hurray: :hurray:
Old Feb 8, 2003 | 09:52 AM
  #33
BLOWN IN NC's Avatar
BLOWN IN NC
Default Re: C5 Vortech Dyno Results? (Yano)
Maybe you should change and go with the ATI, I have never had a problem with a viper GTS or a modena :lol: :lol: of course we were way higher than 120! The racetronix is the way to go.
Old Feb 8, 2003 | 10:34 AM
  #34
7LitreC5's Avatar
7LitreC5
MelloYellow,
You're doing the installation yourself aren't you? Good luck with it. If you have questions post them and I'll be glad to help out if I can.
Old Feb 8, 2003 | 10:36 AM
  #35
7LitreC5's Avatar
7LitreC5
Yano,
You noticed the name change... :thumbs:
Old Feb 20, 2003 | 07:18 PM
  #36
7LitreC5's Avatar
7LitreC5
The time for my Vortech tuning is finally getting close. Xtreme is picking up the car tomorrow. :hurray:
Mike will be doing the tuning on Monday. I am flying down on Saturday will be there for the dyno runs. I borrowed a buddy's digital video camera and plan on taping the dyno activity.
Xtreme will be installing my 3.73s, boost/fuel pressure gauges, and new wheels while the car is there.
