advise on C5 z06 build
Old Nov 29, 2023 | 09:51 AM
acroy's Avatar
acroy
As with all the others, I do suggest ECS.
I think 550whp is a safe target. Maybe they can get you another 50 reliably.
Assume you will have to replace the clutch and rebuild the TT. As others have said, think about wheel hop: diff mounts, trans/diff brace, etc.
Clutch is a very personal choice, there are a lot of options. I am running a Mamo'd RPS BC2 twin carbon and it is a sweetheart, but $$.
have fun!
Old Dec 13, 2023 | 12:31 AM
romandian's Avatar
romandian
i wouldnt overthink it in your case. a base centri kit (6-rib) will make up to 10 psi and should produce around 650 bhp on a ls6.
i would avoid pump boosters in favour of a pump upgrade. not up to date what they offer now, but the (single) "lingenfelter" has been just fine with 60 dekas. 255 lph out of memory. especially if you ditch the stock regulator and do a filter/adjustable regulator in engine bay. hopefully your car has the pump accessible from below.
the only catch with the kits is belt alignement. i had ongoing belt problems until i found a method to do the alignment that works. try to get an rpm belt.
oh, and the other catch is that you might get used to the power and be wanting more in short time. in that case all that has been said by others applies.
edit: you also dont need any fancy catch can systems, just use the oil cap breather that comes with the kits.
Old Feb 14, 2024 | 07:34 AM
fairlady_z33's Avatar
fairlady_z33
Originally Posted by Rkreigh
on street tires as long as you avoid wheel hop, drivetrain should live at the torq level. It's at the limit, but the blower ramps up the power linear which helps avoid the low end pounding at launch which can break stuff
avoid the drag strip launches and the auto will take it You can beef up the 4l65 to hold 1k hp, but not for long!! The stick isn't much better unless you go with a beefed tr6060 which isn't cheap
For my $$ stay sensible with the build and spend time enjoying instead of picking up broken pieces.
Yeah the idea behind this build is to keep it simple and enjoyable. Not trying to do push any limits to be breaking down every other weekend lol
Old Feb 14, 2024 | 07:38 AM
fairlady_z33
Originally Posted by Missileboy
Part of the ECS install was a fuel pump booster module for the 60lb injectors, Stock fuel pump can't support those without the mod. I also added a Double Shot (AMT brand) diff brace to the 3.42SP rear when I put that in before the blower upgrade. If you are buying a Z, then it will come with the 3.42SP.
Maxflow Fuel Pump Booster / Programmable | Vortech Superchargers
I have not upgraded the trans or torque tube (yet) and as Rkreigh says, respect the stock components you don't mod and you'll have a car that is a lot of fun and truly is good as a commuter or weekend fun car that rips.
Gotcha, I might just do twin intank pump kit to just forget it and be set. Ill be doing my homework on it, thanks
Old Jan 24, 2026 | 09:49 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Can’t wait to hear the progress on your plans
