A&A v3 Ti advice
Old 05-16-2024, 01:41 PM
XanBarclay07
XanBarclay07's Avatar
Default A&A v3 Ti advice
I’m planning on putting a v3 Ti on my 2000 Frc with headers and ls6 intake. I want to run 7-8 lbs because everything else is stock but would the standard 3.8 pulley do 8 psi of boost? Or would I need 3.6? Also those with a Similar set up as mine, what are you running?
Old 05-16-2024, 06:26 PM
Josh@AandASuperchargers
Platinum Supporting Vendor
Josh@AandASuperchargers's Avatar
Since you mentioned Ti-trim, I'd start with the 3.8" pulley.
XanBarclay07 (05-16-2024)
Old Yesterday, 08:17 AM
romandian
romandian's Avatar
you can use a smaller pulley and adjust the boost with a restrictor after the filter. easy to change out.
(i have been running 20 psi with "everything else stock" for nearly 10 years now, except the fuel pump.)
To A&A v3 Ti advice
Quick Reply: A&A v3 Ti advice
