BOV filter purpose?
Old Apr 28, 2003 | 01:48 PM
QuickSilver2002's Avatar
QuickSilver2002
Default BOV filter purpose?
So what is the purpose of a filter on the BOV. Does the motor end up breathing in air through the BOV outlet when under certain vacuum conditions?
Old Apr 28, 2003 | 03:59 PM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Default Re: BOV filter purpose? (QuickSilver2002)
That filter is there to dissipate the air coming out of the BOV line. IF that filter was not there, you would have an (optional) C5 Leaf Blower attachment!
I found out how great that works when I lost my BOV filter.... :rolleyes: Swept the entire garage out with one rev of the engine!! :party:
vetterdstr :cheers:
[Modified by vetterdstr, 1:00 PM 4/28/2003]
Old Apr 28, 2003 | 07:36 PM
Red C5's Avatar
Red C5
Default Re: BOV filter purpose? (vetterdstr)
Steve, what kind of BOV do you have now? Do you still get the sputtering soiund when you are out of boost/shifting? I think I need to adjust mine. Glad you're enjoying the C5. :D :cheers:
Old Apr 28, 2003 | 08:45 PM
vetterdstr's Avatar
vetterdstr
Default Re: BOV filter purpose? (Red C5)
lol, I still have the POS ATI BOV... (lots of abreviations there :) ) My car surges at even load on the engine. I am thinking it may be the BOV. This is the second POS ATI BOV on the car though.. At this point I am not sure what is causing it... I am fishing for answers now. :banghead:
vetterdstr :cheers:
Old Apr 28, 2003 | 10:16 PM
Red C5's Avatar
Red C5
What do you mean surging?
Old Apr 28, 2003 | 11:45 PM
vetterdstr's Avatar
vetterdstr
lurching back and forth while the engine is running. It may be computer related, I will check into that too.
vetterdstr :cheers:
Old Apr 29, 2003 | 12:06 AM
TheSVTKid's Avatar
TheSVTKid
Cruising
POS? I know that it may be ugly, and quite a simple part. Though I have had them work for many many years. And quite frankly have had them out flow a rather expencive "BOV" that you call it. If you can find a cheaper "BOV" or a "Bypass valve" that can outflow it, or last it, be my guest. As far as astetics are concerned, it is junk. But as far as saving a belts, or compressor damage due to surge...it's top notch.
I took the filter off mine, and used a foot and a half of that same hose, and ran it up towards to corner of my bumper cover, to do 2 things.
1. then it didn't blow dust up off the ground in construction areas.
2. it deadened some of the sounds that it produced.
EA
Old Apr 29, 2003 | 01:53 AM
vetterdstr's Avatar
vetterdstr
Default Re: BOV filter purpose? (TheSVTKid)
Its ok if you dont agree with me... If I find out it is the problem with my car I will really call it a BIG POS! :)
vetterdstr :cheers:
To BOV filter purpose?
