Need source for modified MSD activation switch
Old Oct 3, 2003 | 01:07 PM
PowerKraus's Avatar
PowerKraus
Default Need source for modified MSD activation switch
Is there a source for the modified MSD activation switch, someone who has them in stock? TBYRNE "might" get them late next week and I want it now...
I am looking for the modified version as opposed to the "fix" of cutting the loop and running it in 4-cylinder mode.
I thought the 4-cylinder mode "sometimes" works while the MSD "fixed version is the true cure.
Am I misinformed?
Power Kraus
1987 Grand National Grocer Getter 11.19@120mph
2003 C5 6 speed w/NX Power
PowerKraus@advantexmail.n :confused:
Old Oct 3, 2003 | 01:09 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Need source for modified MSD activation switch (PowerKraus)
I dont see how running in 4 cyl mode would not work since our coil packs are controlled 4 at a time. When I ran my msd it worked fine in 4 cyl mode
Old Oct 3, 2003 | 01:20 PM
PowerKraus's Avatar
PowerKraus
Default Re: Need source for modified MSD activation switch (ICULUKN-C5)
Thanks,
I remember reading somewhere that there was actually some kind of voltage issue where the MSD unit could not pick up the signal. Eh, you never know, so that is why I asked.
Sounds like it was balogna eh? So I'll get the regular 'ol MSD unit and make the modification.....is the only change setting it up for 4-cylinder mode?
...the last thing I want to do is spray a 100 shot past the rev limiter...I hate the school of hard knocks!
Thanks again
Robert
Old Oct 3, 2003 | 01:31 PM
ICULUKN-C5's Avatar
ICULUKN-C5
no worries.... I took mine out since I launch on the bottle... and hated the bog at the beginning..
Old Oct 3, 2003 | 05:22 PM
Allgonoshow's Avatar
Allgonoshow
Mine worked fine before I tossed it. All window switches have to be in 4 cyl mode to work on the C5. It's just the way it comes out of the PCM. The mod for msd was to make sure the switch could pick up and read the small 5V tach signal coming out of the PCM. I checked my car and a few other LS1's and see a 12V one. Have yet to see this mysterious 5V issue. Some guys did need to send it out to work and it came back good. Others have gotten them back and they still don't work, but that could have been from not tapping into the correct wire for the tach.
Old Oct 13, 2003 | 12:57 PM
PowerKraus's Avatar
PowerKraus
Just for you guys following-up on this thread, I purchased an "unmodified" window switch, installed it via 4-cylinder hook-up as mentioned by other list members, and the thing works perfectly.
So for those of you thinking of needing to send it in for another $35.00 mod, think twice. You may not need it, I didn't
I hope this topic is found helpful for other readers....
Power Kraus
PowerKraus@advantexmail.net
To Need source for modified MSD activation switch
