Almost Spraying
Old Mar 1, 2004 | 01:11 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Default Almost Spraying
Picked up this kit off of ebay:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWN%3AIT
I know it looks a bit dirty but it comes pretty complete. It has a 10# bottle w/ high flow valve, blow down tube, gauge and bottle nut, two NOS N2O noids, a purge noid and a fuel noid and plenty of hose. I ordered a Harlan window switch also. So all I need is the relay (which I have) and some microswitches and toggle switches. :thumbs:
I figure I will try it as a dry kit and if that doesn't work well because of my Vortex intake I can convert it to wet.
Can't wait to spray!
Old Mar 1, 2004 | 10:19 PM
MC TORCH RED's Avatar
MC TORCH RED
Default Re: Almost Spraying (5 Liter Eater)
:thumbs: i will spray for the first time next week also, good luck. :cheers:
Old Mar 1, 2004 | 11:22 PM
402Sam's Avatar
402Sam
Default Re: Almost Spraying (MC TORCH RED)
Be ready to be addicted to the spray.. :reddevil
Old Mar 1, 2004 | 11:25 PM
BlackMagicC5's Avatar
BlackMagicC5
:seeya Me too, me too! Mine goes down friday for a nitrous install. I picked up a nx wet kit from another forum member. I can't wait. Good luck to both you guys. I can't wait til we get some results on here. :hurray:
Old Mar 1, 2004 | 11:38 PM
MC TORCH RED
Default Re: Almost Spraying (KillerVette99)
:eek: :D :thumbs:
Old Mar 1, 2004 | 11:46 PM
washguy's Avatar
washguy
So MC would that be March6 that you would be spraying?...gotcha! :lol: :yesnod: Wash
Old Mar 1, 2004 | 11:56 PM
MC TORCH RED
Default Re: Almost Spraying (washguy)
who me????????????? :crazy: :sleep:
Old Mar 2, 2004 | 12:34 AM
zoomz's Avatar
zoomz
Do yourself a favor and set it up wet from the start so you dont have the headache of trying to get a dry system to work or possably hurting your motor or maf.
Also test the solenoids before installing them .
My 2 cents :p:
[Modified by zoomz, 11:35 PM 3/1/2004]
Old Mar 2, 2004 | 12:29 PM
5 Liter Eater
St. Jude Donor '11
Default Re: Almost Spraying (zoomz)
Will definitely test the noids first! Freezing the MAF and the smaller injectors on some years of Y bodies VS F bodies scares me on the dry kit but puddling, leaning out the rear most cylinders and the fuel noid failing scare me as well. I'm still on the fence but I think I will start out dry. If it's too lean I'll convert.
:cheers:
Old Mar 5, 2004 | 11:53 AM
FRC sexi blk's Avatar
FRC sexi blk
are you more likely to lean out the rear cylinders with a wet kit or a dry kit?
Old Mar 5, 2004 | 12:03 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Almost Spraying (cute301guy)
you have a better chance in leaning out with a dry kit IMO. Since you are adding fuel with a wet kit you are sure to get the proper amount of fuel when you are spraying; instead of relying on the injector.
Old Mar 5, 2004 | 12:06 PM
FRC sexi blk
Default Re: Almost Spraying (ICULUKN-C5)
I think that's a good thing. with a wet kit the nitrous and fuel have to flow equally into the manifold and into each intakeport. That seems more risky. with a dry kit (and larger injectors) the fuel will be equally injected into the intake head ports and the nitrous is coming much further downstream near the intakebox so it has more time to mix with the air and flow equally into the manifold.
what do you other guys thinK?
Old Mar 5, 2004 | 12:38 PM
ICULUKN-C5's Avatar
ICULUKN-C5
The way your car adds more fuel is by checking the Long term fuel trim tables at WOT. These tables change during your daily drive. You are now fooling your car into thinking it is lean, by spraying -20 degree gas, causing the car to flood the injectors to the last reading on your LTFT table. Besides, when nitrous comes out of the fogger it is at 900-1200 psi the back 2 cylinders are getting more nitrous anyway. The only way to ensure equal distribution of nitrous and fuel is to go direct port.
Old Mar 5, 2004 | 12:44 PM
FRC sexi blk
I agree 100% with direct port. but for cheap, easy power, dry and wet is the beest. I have larger injectors plus an ls1 edit for my nitrous tune. I should be rocking :)
To Almost Spraying
