window switch or WOT switch?
Old May 10, 2004 | 10:23 AM
vettekid00's Avatar
vettekid00
Default window switch or WOT switch?
I am not 100% sure what the WOT poopiech does. I assume that when the pedal is to the floor, the nitrous is activated. The question I have is does it spray in every gear from the point i hit the activation switch? Thanks for any help!
Old May 10, 2004 | 10:55 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: window switch or WOT switch? (vettekid00)
First forget anything you say on the fast and the furious. No one uses a button to activate nitrous. A WOT switch completes the circuit when the microswitch (Under the pedal) is depressed. A window switch is completes the circuit at a designated 'window' between two RPM points. If you had to use one or the other, use the WOT switch as N2O is a WOT system. If you used a window switch and did not have a WOT switch in parallel, then your nitrous would come on everytime your car saw 3000 RPM's. Not good.
Old May 10, 2004 | 10:59 AM
vettekid00's Avatar
vettekid00
Default Re: window switch or WOT switch? (ICULUKN-C5)
thanks alot. I will have to pick me up a window switch from mike at BMN racing.
Old May 10, 2004 | 11:56 AM
Allgonoshow's Avatar
Allgonoshow
Good choice!
Old May 10, 2004 | 05:28 PM
mikey94_95's Avatar
mikey94_95
Sweet vettekid00; you know where to contact me!
Old May 10, 2004 | 11:44 PM
Robert56@RNS's Avatar
Robert56@RNS
Collections Hold
Default Re: window switch or WOT switch? (mikey94_95)
What the h...
Old May 11, 2004 | 12:12 AM
mikey94_95's Avatar
mikey94_95
Default Re: window switch or WOT switch? (Robert56)
HAHA! LOL!
I should've said: That's sweet dude
mike@bmnracetech.com if you need to contact me.
To window switch or WOT switch?
