NX Install Instructions?
Old May 12, 2004 | 04:42 AM
TexCorvette's Avatar
TexCorvette
St. Jude Contributor
Default NX Install Instructions?
I have a complete NX Wet kit with purge, hottle heater, bottle opener, MSD window switch, WOT switch and so on.
Does anyone have a complete instructions for our cars with pictures. I have found a few on the web, though not specificaly for this kit or very detailed. This is my first time and want to do it right. Will be taking the interior apart for the install this week. Thanks guys.
Old May 12, 2004 | 08:32 AM
Inelpaso's Avatar
Inelpaso
Default Re: NX Install Instructions? (TexCorvette)
Do u have the panel switch? If so the bottle heater and the opener are fairly straight forward. Finding the tach wire for the window switch was a little difficult on my 98. Do a search on the forum. Its a different wire form the 01 and up. I emailed a basic diagram for you. Be careful that no hot wires touch the nirtous lines and double check the wiring before attaching the solinoids, they are easy to ruin, I learned he hard way.
Frank
Old May 12, 2004 | 07:03 PM
TexCorvette
Default Re: NX Install Instructions? (Inelpaso)
Thanks Frank! The wiring diagram will help me get started! Does anyone else have any written instructions, or step by step pictures & write-up of their own isntall? I'm also going to try wire in my own timing retarding divice so that I can have my regular tune when not on the bottle.
Old May 13, 2004 | 07:49 AM
TexCorvette
Got the passanger side all taken appart. Will test wire everything up today with the diagram frank gave me, and then start the install on Friday! Any additonal instructions anyone can post or send me will help.
Few questions:
1) what are the exact plugs I should get and what gap?
2) how are you all installing the blowdown? I might not install it in the center compartment because I have a sub there now
Old May 13, 2004 | 10:24 AM
C5 YA's Avatar
C5 YA
Hope this helps.
Old May 13, 2004 | 10:27 AM
C5 YA's Avatar
C5 YA
Default Re: NX Install Instructions? (C5 YA)
Also,
http://www.nitrousexpress.com/Instructions/stage1.pdf
http://www.nitrousexpress.com/Instructions/purge.pdf
Old May 13, 2004 | 10:48 AM
Inelpaso's Avatar
Inelpaso
Marcus...Plug link: http://forums.corvetteforum.com/zero...050483#3050483
Seems most choose NGK TR6 @ .035 - .040
Could you route the bow down out the wheel well?
Frank
Old May 14, 2004 | 11:24 PM
78Vette-SA's Avatar
78Vette-SA
Just did my own and first time at something like this. I'm one happy glued to the seat kinda guy now.
http://home.hvc.rr.com/joesvette/98vette/nx.htm
Old May 19, 2004 | 05:33 AM
TexCorvette
Default Re: NX Install Instructions? (78Vette-SA)
Thanks everyone, I'm about 70% done, and its a real clean looking setup without lines all over.
On my PCM, there is only 2 white wires, one on the uper, and the other on the lower. Each block is numbered 1-16, for a total of 32. There is no 35pin? So am I assuming correctly to just T into the only white wire in the top block for the RPM on a 98?
Old May 19, 2004 | 01:51 PM
Inelpaso's Avatar
Inelpaso
Try pin #10 on the red connector. I think thats the one for the 98's.
It's a white wire regardless.
[Modified by Inelpaso, 12:53 PM 5/19/2004]
Old May 19, 2004 | 05:09 PM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Call Nitrous Express and they can fax you a copy.
To NX Install Instructions?
