pcv catch cans
Old May 19, 2004 | 01:55 PM
wrustywrench's Avatar
wrustywrench
Default pcv catch cans
I have a maggies LS1, I have a checkvalve on the pcv line, but no catch can for oil...should I have one????? is this a must????? only running 5 psi boost...
Old May 19, 2004 | 02:29 PM
blu00rdstr's Avatar
blu00rdstr
Default Re: pcv catch cans (wrustywrench)
I don't believe anyone has blown a motor on only 5psi boost. That was the safe upper limit as a rule of thumb on a stock motor.
If you see oil in your throttle body, that means it's accumulating towards the back of the intake manifold, being too heavy to get lifted into the first 7 intake runners. The oil enters the last runner on the passenger side, and follows that up and over into cylinder 7 next to the brake booster. For high boost or borderline tuned applications that may end up to be a problem. For low boost motors it mostly ends up as an 'oil in intake port 7' curiosity when someone removes their intake manifold.
Old May 19, 2004 | 02:36 PM
IM QUIKR's Avatar
IM QUIKR
It's cheap insurance. In fact, the cheapest mod you will probably do.
Old May 19, 2004 | 03:28 PM
mdhmi's Avatar
mdhmi
Default Re: pcv catch cans (drcoffee)
Ordered mine last night. Figured it's a little extra peace of mind, and for under a hundred bucks why not..
Mark
Old May 19, 2004 | 04:07 PM
QuickSilver2002's Avatar
QuickSilver2002
Default Re: pcv catch cans (mdhmi)
I feel pretty strongly about this one (as some of you may know). I would ask you this simple question. Would you run gas with an octane of 70 or so in your boosted motor? Well, that is what oil contamination can do to your effective octane.
I spent 6 months fighting KR problems on my motor. Guess what the problem was all along.
Old May 19, 2004 | 05:29 PM
mdhmi's Avatar
mdhmi
Default Re: pcv catch cans (QuickSilver2002)
A missing catch can ? I ordered mine last night.
Cheers,
Mark
Old May 19, 2004 | 06:21 PM
QuickSilver2002
It was the PCV system in general. A catch can will help, but I'm not sure if it will solve all problems related to oil contamination in the intake. I removed mine completely and I'm now making tons of power on pump gas.
My situation may be unique due to more blowby... I just know that the PCV was causing all kinds of problems on my motor.
Old May 19, 2004 | 08:01 PM
king_pin's Avatar
king_pin
St. Jude Contributor
[QUOTE]I feel pretty strongly about this one (as some of you may know). I would ask you this simple question. Would you run gas with an octane of 70 or so in your boosted motor? Well, that is what oil contamination can do to your effective octane.
a PVC catch can is a must on a boosted motor
Old May 19, 2004 | 11:12 PM
dads01dream's Avatar
dads01dream
Default Re: pcv catch cans (king_pin)
Anyone have a line on a pretty good catch-can setup/kit?
Old May 19, 2004 | 11:26 PM
king_pin's Avatar
king_pin
Default Re: pcv catch cans (dads01dream)
I just had one installed over at Xtreme give bill a call it works
awesome!!!! 480-517-4969
Old May 19, 2004 | 11:45 PM
Bill Reid's Avatar
Bill Reid
I'm not going to take credit for anybody's hard work in researching a senseable EFFECTIVE solution to overpressure of the crank case under boost conditions. We now buy our oil seperator kits from Lingenfelter. They did the home work and they sell a great kit. Give Tim at LPE a call or JP over at 21st Century. Those guys hooked Xtreme up... they will you too! I will be stocking LPE's oil seperator kits as well... as soon as I catch up with the current/past customers in need of this kit.
[Modified by Bill Reid, 9:47 PM 5/19/2004]
Old May 20, 2004 | 08:20 AM
IM QUIKR's Avatar
IM QUIKR
Default Re: pcv catch cans (Bill Reid)
Bill,
Do you have photos of the unit and pricing?
Old May 20, 2004 | 08:23 AM
wrustywrench
LPE has pics on their web site, pricey at 149.00.........I chose to go with accurate machine works for 80.00.......
Old May 20, 2004 | 08:55 AM
IM QUIKR's Avatar
IM QUIKR
Wrusty,
Is there a filter element in the can? Do they offer a sight glass for fluid level?
[Modified by drcoffee, 7:56 AM 5/20/2004]
Old May 20, 2004 | 09:12 AM
Bill Reid's Avatar
Bill Reid
Bill,
I'll see what I can dig up... in the meantime maybe KingPin could post some pics of his set up?
Here is the advertisement on LPE's website:
http://www.lingenfelter.com/lingenfe...03&pf%5Fid=591
Old May 20, 2004 | 10:27 AM
wrustywrench
I am still investigating, I see a baffle , but no filter.....As far as a sight glass, i see no need, just drain her every week ...I am sure you are not going to get a lot of oil. I dont see why an air line filter would not work , oil seperator??
Old May 20, 2004 | 05:10 PM
blu00rdstr's Avatar
blu00rdstr
I initially just had the ACE Hardware air/oil separator with a checkvalve. The oil level in the glass never got higher than 1/4". Oil in the glass would splash onto the filter which would saturate. Vacuum would then draw oil and air from the separator.
Here's my setup with the Accurate Machine Works oil catch can added.
To pcv catch cans
Old May 20, 2004 | 05:37 PM
HIGHRPM's Avatar
HIGHRPM
Check out the Evac Breather Canister from Shogun Industries. http://www.shogunindustries.com/cgi-...oducts.htm#new I installed this unit on my car last week. The F1-R S/C and bracket takes up the space where it would normally be mounted, so I made a bracket that comes off the back side of the S/C bracket and mounts the canister along side the passenger side fender well. I also made a right angle air manifold that mounts on the firewall. I made braided stainless lines to connect the valve cover output to the air manifold, from the air manifold to the canister, then from the canister a line connects to the original destination point. I polished the canister, both brackets, and the air mainfold...it really looks great.
[Modified by HIGHRPM, 11:49 AM 5/21/2004]
Old May 20, 2004 | 05:41 PM
rplaster's Avatar
rplaster
Default Re: pcv catch cans (blu00rdstr)
I'm confused, isn't the line that goes to the air fiter the only way that oil could get sucked into the intake? From the picture that line has nothing to stop oil from being sucked in. I talked to Andy about this and that is where he said to put the seperator.
Old May 20, 2004 | 06:08 PM
IM QUIKR's Avatar
IM QUIKR
I am still investigating, I see a baffle , but no filter.....As far as a sight glass, i see no need, just drain her every week ...I am sure you are not going to get a lot of oil. I dont see why an air line filter would not work , oil seperator??I initially just had the ACE Hardware air/oil separator with a checkvalve. The oil level in the glass never got higher than 1/4". Oil in the glass would splash onto the filter which would saturate. Vacuum would then draw oil and air from the separator.
Personally. I'd put the check valve right up against the intake and keep the whole line boost free.
