SC install progress update
Old Jun 21, 2004 | 12:48 AM
GTP's Avatar
GTP
Default SC install progress update
Thanks for everyones help on the crankshaft bolt. I ended up getting a really large breaker bar and a 2 foot extension to budge it! After that the pinning process went smoothly. I was a little worried that the pins took little effort to slide into the new hole but figured it was ok.
So today I got the crank pinned, suspension and steering rack reinstalled, heat exchanger mounted and plummed with pump, wiring and hoses.
I was set to install the supercharger and work on the fuel pump tomarrow when a setback came into play. As I was torqueing the new valley cover down the rear bolt hole cracked through. My heart sunk when I heard the sound and felt the torque wrench ease up. Here is a picture below:
The metal is extremely thin around those edges on both of the rear holes. I will call Magnuson tomarrow.
So it looks like the car won't be complete until at least Wednesday. I have a new fuel filter and plugs coming in Tuesday anyhow to no real big delay.
I do see the instructions call for 2 throttlebody gaskets to be purchased. Does'nt the C5 use a rubber gasket built into the intake manifold? What gaskets am I supposed to use?
Thanks,
Aaron Lephart
http://www.StopFORCE.com
Old Jun 21, 2004 | 07:43 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Default Re: SC install progress update (GTP)
Sorry to hear about the valley cover but since your so close to Magnuson it's not really a big deal anyway.
The gaskets your supposed to use for the throttle body should be included in the kit atleast mine were, you need them because the power steering reservoir is relocated and the bracket gets bolted in between the throttle body and the blower
Old Jun 21, 2004 | 11:44 AM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Default Re: SC install progress update (runamuk)
Good luck. Since you've got the crank pinned you should be past the worst of it...minor setbacks like this one aside.
Old Jun 22, 2004 | 12:55 AM
GTP's Avatar
GTP
Default Re: SC install progress update (SleepieAce)
Hello,
Talked to Tony up at Magnuson today. I'm not the only one who has cracked one of these recently. Turns out its not a casting problem or a fault the problem lies with the torque specs. He recommends 11ft lbs instead of the 18 the manual mentions. He was nice enough to send another one out today and send a prepaid mailer for the broken one to send back. I have to say......everyone at Magnuson has been fantastic to deal with. Excellent customer service!
On a side note I started buttoning up misc little things around the car until my new valley cover arrives. I found this 20inch long wire coupler that the instructions seem to indicate is for the 02+ 5 wire MAF. However after closer inspection I saw the loom of wire had 6 wires in it. Is this the correct extension harness? It does'nt look like its the same type of connector either.
Thanks,
Aaron Lephart
Old Jun 22, 2004 | 07:58 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
It sounds like the harness for the TPS
Old Jun 23, 2004 | 01:03 AM
GTP's Avatar
GTP
You are correct! Whew!
Thanks,
Aaron Lephart
To SC install progress update
