Exedy Twin Disk..........
Old Sep 3, 2004 | 01:33 PM
mdhmi's Avatar
mdhmi
Andy - I'm not sure what a good deal is. The only numbers that have been posted are $1,650 - $1,750 ish. That just really strikes me as high for a clutch ( I realized it does include a replacement flywheel ). Perhaps I'm just too picky..
Mark
Old Sep 3, 2004 | 01:39 PM
SleepieAce's Avatar
SleepieAce
From: Kentucky basketball is life the rest is just details
Glad you're happy Kingpin.
Old Sep 8, 2004 | 02:11 AM
KDubb's Avatar
KDubb
Mark
agreed
Old Sep 8, 2004 | 08:16 PM
Supercharger John's Avatar
Supercharger John
Cruise-In IV Veteran
Yo Kingpin wasssss up?!?!?! I'm glad to hear that your Excedy Clutch worked out....
I absoultely love mine...it's awsome the way it grabs. I love everything about it. Not to mention Andy was great about sending the clutch out to me ASAP since I was having some motor work done at the time.
Needless to say, yes it's a bit more, but well worth the investment for us go fast junkies!
Enjoy
Old Sep 8, 2004 | 10:31 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
Originally Posted by Andy@AandACorvette
Mark: What would you consider a good deal? I have a bunch on the shelf.
Whatever a "good deal" is Andy I will take one too... LOL
OK OK.. supercharger install first.. but I cannot resist ordering the drag radials.
I am ready for one.. $1700 is a lot to shell out for a clutch though.
Old Sep 8, 2004 | 11:08 PM
king_pin's Avatar
king_pin
St. Jude Contributor
But it's the best clutch you will ever own I am so
happy to have that chatering POS out of my car.
Old Sep 8, 2004 | 11:20 PM
mdhmi's Avatar
mdhmi
Originally Posted by king_pin
I am so happy to have that chatering POS out of my car.
Which chattering POS did you have previous to the Exedy?
Mark
Old Sep 9, 2004 | 12:48 AM
king_pin's Avatar
king_pin
Mark
Sorry Mark, it was the Spec III
Old Sep 12, 2004 | 09:55 PM
L.Lopez's Avatar
L.Lopez
Has anyone been able to compare the Exedy twin disk setup against a McCleod twim disc setup.I've installed lots of McCleod's but never an Exedy.
Maybe someone has so input?
Old Sep 13, 2004 | 07:47 AM
supercoupe01's Avatar
supercoupe01
Glad your happy, I'm getting one put in my car this week.
Old Sep 13, 2004 | 08:46 AM
RoadRebel's Avatar
RoadRebel
The McCleod has the goofy pedal effort feel..especially on release.hard to explain, but it feels like its always draggin on release..
The exedy, other than the higher effort has the same feel as stock.
Phil
Old Sep 13, 2004 | 05:21 PM
king_pin's Avatar
king_pin
Thanks you will love it!!!! I need to learn how to drive it all over again.
You can't try to slip it like the Spec Let just say I have stalled it a few times
Old Sep 13, 2004 | 05:34 PM
  #33
L.Lopez's Avatar
L.Lopez
Phil
Thank you for the information.
Old Sep 19, 2004 | 10:07 PM
  #34
2k1vert's Avatar
2k1vert
I've tried stock, 2 McLeod twin streets (1 all organic and 1 with 2 sides organic, 2 sides kevlar) and I can only say that it was always a bear to shift into reverse new and after they were broken in.
The pressure plate design of McLeod is an old design an really just does not compare in my book to the quality of Exedy. I will also say the clutch is a little easier than the McLeod when new and like others have said the engaugement point is roughly half way off the floor.
I'm very happy with the Exedy and thrilled that my car finally shifts through all the gears like when it was stock.
Old Sep 19, 2004 | 10:16 PM
  #35
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Since I am getting my car back soon. What is the break-in procedure???
Old Sep 19, 2004 | 10:27 PM
  #36
2k1vert's Avatar
2k1vert
I've read different things, but I'm holding the install instructions in hand and they read on Page #6 at the top under Caution during operation section:
After installation, drive carefully and gently for approx. 300 miles (500km). If the clutch is used in a condition where the friction surface is not contacting fully with the mating surface; It will cause burning, judder/shudder or short life.
Then after 300 miles of pampering, raise H3ll
Old Sep 19, 2004 | 10:42 PM
  #37
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
Thanks, I can do that
To Exedy Twin Disk..........
Old Sep 19, 2004 | 11:01 PM
  #38
Scubanme's Avatar
Scubanme
Thanks for letting us know the results and it sounds like a winner.
Old Sep 20, 2004 | 12:32 AM
  #39
kumar75150's Avatar
kumar75150
The clutch will break in a lot better if you just do 20 miles of stop and go traffic than if you drive 300 miles on the freeway at a constant speed.
Old Sep 20, 2004 | 07:32 AM
  #40
supercoupe01
Why is that? Is that what Exedy recommends?
Thanks.
