Traction Issues
Old Sep 13, 2004 | 01:15 PM
Blue Lightening's Avatar
Blue Lightening
Default Traction Issues
I'm looking to try to solve my traction problem and am wondering what some of you FI and Nitrous guys with the real big horse power have done to deal with the traction issue???
My Vette is only putting out 456 rwhp. I got tubbed and put 345x30zrx19 Michelin Pilot Sports on the rear and am dissapointed in the tires performance. If first gear they break loose from a roll whack second and forget it, your sliding around like a buffalo on ice skates to the point where nailing it in low gears on a public highway is not a sane thing to do.
Old Sep 13, 2004 | 05:33 PM
IM QUIKR's Avatar
IM QUIKR
I thought I have seen folks say that 3.42s were preferred on FI applications. Your 3.90 gears may be too tall.
Old Sep 13, 2004 | 06:04 PM
MelloYellow's Avatar
MelloYellow
How much sidewall do you have on the 19" ?
Old Sep 13, 2004 | 07:18 PM
RoadRebel's Avatar
RoadRebel
pilot sports suck..period..but they do last about 10 times longer than the bfg drag radials.
I can currently black patch the sports and any speed in the first 4 gears.
Phil
Old Sep 13, 2004 | 08:45 PM
CJS's Avatar
CJS
Nitto Drag radials, 555 R work for me. You can spin them, but they are much better than regular tires. Cornering is only down 10% or so.
Old Sep 14, 2004 | 08:28 AM
Blue Lightening
Your correct, the 390 gears are a blast to drive but they are too tall...but still I see these posts where some of these guys have 600 & 700 rwhp. My Vette is slippery with just 456, so what have they done to the car to handle that, or they just plain crazy???
Old Sep 14, 2004 | 04:56 PM
MiamiDave's Avatar
MiamiDave
Go with the nitto RII street/track tire. And the 3.90 gear set is pretty low, especially if you have the Z06 MN12.
I can lay down almost all 425+ RWHP in first gear on 80 degree+ days with my 335/30 18's Michelins Pilots. Second gear is locked down tight from a punch always. Stock gears and MN6-speed.
Thinking of upgrading for the cooler weather and future blower applications to the Nitto's though. Avoid DR's as they can be nasty at high speeds...
Old Sep 14, 2004 | 09:17 PM
CJS's Avatar
CJS
Avoid Drag radials at what high speeds? My Nitto Drag radials are sold as a rock at 135 mph.
Old Sep 14, 2004 | 10:01 PM
VetteMan4Life's Avatar
VetteMan4Life
Not trying to hijack the thread, but is anyone running the 19/20 inch package from WCC with Continental tires on their FI car? If so how are they with the high HP?
Old Sep 15, 2004 | 12:38 AM
lutey's Avatar
lutey
Default Nitto's vs Pilot Sport Cups
I'm in the same boat, but am at 470 rwhp. I'm currenlty deciding between the Nitto 555R Drag Radial (pretty sticky, somewhat flexible sidewall which will help tire flex during acceleration) or the Pilot Sport Cups (sticky R compound but at 80 treadwear should last similarly to nitto's), and supposedly a really good tire for dusty roads which I have in Las Vegas. The cups are also an autox tire, so handling will probably improve.
I'm trying to find someone that has experience with the Pilot Sport Cups, but currently no dice on this forum.
Old Sep 15, 2004 | 01:03 AM
HurricaneZ's Avatar
HurricaneZ
Maybe I've been out of the scene for awhile but does nitto make a 555r for stock or z06 sizes now?
Old Sep 16, 2004 | 12:47 AM
lutey's Avatar
lutey
Default Nitto 555R
Yes they do. They've made them for about 7 months now.
Old Sep 16, 2004 | 03:38 AM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
I run 295 BFG G-Force KDs on my HREs. I'm lowered a bit with C5R Spings, QA-1 shocks, and T-1 Bars. After they are warm, with a bit of throttle control, I can put down most of my power on the street once I get going in second. I can actually use quite a bit of first as well.
Now of course I can ice skate all day, which is fun once in a while, but not condusive to good excelaration..
I've also been called crazy once or twice...
JB
Old Sep 16, 2004 | 07:04 AM
Blue Lightening
How much handling do you sacrifice do you loose when you switch those nitto RII street/track tire and or BFG G-Force KDs????
I sometimes think I expect too much. I wanted the power, now that I got it, I'm bitching about not having traction and I guess I'll be doing the same thing if I have power and traction but loose handling and am looking for the best of all three worlds.
Old Sep 16, 2004 | 08:55 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
I have Expedia S0-1s 345/35/18s on my 97' for street driving and get 1.75 60's in the 1/4.......they have a 140 tread rating and hook pretty good on the street.......and do fine in wet weather & auto xing. Short of the 345/30/18 drs at 1.52 60's I don't think I can find a better 345/35 to use on the rear for street/strip duty.
Only thing for sale new now is SO-3s in smaller sizes.
Good luck, the tread rating will need to be soft for the HP to hook on the street
Old Sep 16, 2004 | 09:22 AM
Slowhawk's Avatar
0Slowhawk
Former Vendor
I run Nitto 555r 's on the street/track and they hook up my 500+hp real good.Have also cruised at 170mph and the car was stable.
Old Sep 16, 2004 | 07:37 PM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default I'm crazy too!
JB
I love my 3.90's in 4th, 5th, and 6th where I do most of my street driving.
I have a coupe ('97) and my overall ratio (trans x rear end) in 1st gear is about the same as a ZO6!...Check for yourself!
As JB says, a little throttle control is necessary!
And for some of us that may be as hard as learning to play the violin, most of us would be hard pressed to play the harmonica!
Roy
To Traction Issues
By Michael S. Palmer | 2026-06-03 09:39:05
