rebuild forged bottom
Old Oct 24, 2004 | 10:05 PM
MRC5's Avatar
MRC5
Default rebuild forged bottom
i going to rebuild my c5 engine to forged bottom .
what is the best parts i should get ? i need pistons . rods . bearing .all bolts and gasket . (( i'll not need to get new crank i'll use stock one ))
what is the best or better for procharger , cam ...224\224 114 lsa or lingenfelter gt2-3 cam
and which heads are recommended ?
Old Oct 24, 2004 | 10:34 PM
mdhmi's Avatar
mdhmi
You didn't blow it up already did you?
Mark
Old Oct 24, 2004 | 10:40 PM
XCELER8's Avatar
XCELER8
This is another one of those whats your favorite color question. Each tuner has there favorite parts. Here are some of the more popular ones.
Heads LS6, AFR, or 6.0
Cam 21 Cent Blower cam, MTI G1
Pistons Diamond, Wiseco
Rods Eagle, Lunati
Gaskets, most use Cometics(spelling is wrong)
Bolts, most use same ARP
Most tuners use the Stock crank. Its good to around 800fwhp
Hope that helps
Jon
Old Oct 25, 2004 | 12:21 AM
MIKE-C5's Avatar
MIKE-C5
St. Jude Donor '05-'06-'08
Default Motor
If you are going to take Motor apart, change the crank.......... I just did the same thing and I think its worth it.
Old Oct 25, 2004 | 12:52 AM
7.0sc SuperVette's Avatar
7.0sc SuperVette
From: Sunny Earthquake Country, USA On the Left Coast (which is becoming more Right!)
Default And the corollary...
And the corollary...if you're going to change the crank, might as well put in a 4 incher!
Why not!
Roy
Old Oct 25, 2004 | 12:58 AM
flynbludream's Avatar
flynbludream
It's proven itself way past that point.
Old Oct 25, 2004 | 01:09 AM
kumar75150's Avatar
kumar75150
ya you dont really need to upgrade the crank unless you want to increase displacement
there are people that have pushed over 1000 hp on the stock crank
Old Oct 25, 2004 | 06:24 AM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Here is an idea of what I'm doing and go from there.
346 with Diamond pistons,H beam rods (9.5-1)
AFR 205 heads
216/220 .580/.580 on 115 Cam
lowering oil pump pressure for 60psi at WOT (80+psi now)
running my P1 at 10lbs
Easy 650rwhp with killer midrange.
Old Oct 25, 2004 | 10:50 AM
MRC5's Avatar
MRC5
i did blow it ...
Old Oct 25, 2004 | 11:11 AM
MRC5's Avatar
MRC5
Rods Eagle, Lunati
Hope that helps
Jon
thanks for you reply ...
i know what the parts i need , but i don't know what's the part no# i saw many different rods parts no# and pistons .
which piston for low compression .
check this out :
Flat top/3.905 bore/3.622 stroke/6.098 rod/1.340 comp. height/.945x2.500 wrist pin/-2cc valve relief $565.99
DP11502 Flat top/3.905 bore/3.622 stroke/6.125 rod/1.315 comp. height/.927x2.500 wrist pin/-2cc valve relief $565.99
DP11503 Flat top/3.905 bore/3.622 stroke/6.125 rod/1.314 comp. height/.927x2.500 wrist pin/-8.6cc valve relief (Boost/up to 20psi) $585.99
DP11504 Flat top/3.905 bore/4.000 stroke/6.125 rod/1.130 comp. height/.927x2.500 wrist pin/-2cc valve relief $585.99
DP11506 Flat top/4.100 bore/4.000 stroke/6.125 Rod/1.125 comp. height/.927x2.950 wrist pin/-7cc valve relief $585.99
DP11507 Flat top/4.110 bore/4.000 stroke/6.125 Rod/1.125 comp. height/.927x2.950 wrist pin/-7cc valve relief $585.99
DP11508 Flat top/4.120 bore/4.000 stroke/6.125 Rod/1.125 comp. height/.927x2.950 wrist pin/-7cc valve relief $585.99
DP11509 Flat top/4.130 bore/4.000 stroke/6.125 Rod/1.125 comp. height/.927x2.950 wrist pin/-7cc valve relief $585.99
DP09013905 Diamond Pro-Select Piston Rings, 3.905 Bore, 1.5 - 1.5 - 3.0 mm $179.99
DP09014100 Diamond Pro-Select Piston Rings, 4.100 Bore, 1.5 - 1.5 - 3.0 mm $179.99
DP09014110 Diamond Pro-Select Piston Rings, 4.110 Bore, 1.5 - 1.5 - 3.0 mm $179.99
DP09014120 Diamond Pro-Select Piston Rings, 4.120 Bore, 1.5 - 1.5 - 3.0 mm $179.99
DP09014130 Diamond Pro-Select Piston Rings, 4.130 Bore, 1.5 - 1.5 - 3.0 mm $179.99
DP11510 Diamond Pistons LS1 Forged Dished Piston set , 4.030" BORE / 3.622" Stroke / 6.100" Rods / .945 wrist pin X 2.500" $569.99
DP11511 Diamond Pistons LS1 Forged Dished Piston set , 4.060" BORE / 3.622" Stroke / 6.100" Rods / .945 wrist pin X 2.500" $569.99
DP11512 Diamond Pistons LS1 Forged Dished Piston set , 4.030" BORE / 3.622" Stroke / 6.125" Rods / .927 wrist pin X 2.500" $569.99
DP11513 Diamond Pistons LS1 Forged Dished Piston set , 4.060" BORE / 3.622" Stroke / 6.125" Rods / .927 wrist pin X 2.500" $569.99
DP09154030 Diamond Pro-Select Piston Rings, 4.030 Bore, 1.5 - 1.5 - 3.0 mm $179.99
DP09154060 Diamond Pro-Select Piston Rings, 4.060 Bore, 1.5 - 1.5 - 3.0 mm $179.99
EAGLE 3D 6.125" CONNECTING RODS 2.100"CRANK, .927"PIN, .940" $599.99
Federal Mogul LS1 Main Bearing Set, Competition Series Super Duty Alloy, 3/4 Groove (STD) $69.99
FED152M-1 Federal Mogul LS1 Main Bearing Set, Competition Series Super Duty Alloy, 3/4 Groove (+1) $69.99
FED152M-10 Federal Mogul LS1 Main Bearing Set, Competition Series Super Duty Alloy, 3/4 Groove (+10) $69.99
FED152M-1X Federal Mogul LS1 Main Bearing Set, Competition Series Super Duty Alloy, 3/4 Groove (1X) $69.99
FED7100CH Federal Mogul LS1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (STD) $69.99
FED7100CH-1 Federal Mogul LS1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (+1) $69.99
FED7100CH-9 Federal Mogul LS1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (+9) $69.99
FED7100CH-10 Federal Mogul LS1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (+10) $69.99
FED7100CH-11 Federal Mogul LS1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (+11) $69.99
FED7100CH-1X Federal Mogul LS1/SBC Rod Bearing Set, Competition Series, Super Duty Alloy, Chamfer (+1X)
ARP 12pt LS1 Head Studs $279.99
ARP234-4110 ARP LS1 Head Stud Kit (hex nuts) $215.99
ARP134-3609 ARP LS1 Hex Head Bolt Kit $154.99
ARP234-5608 ARP LS1 Main Stud Kit $199.99
ARP234-6301 ARP Pro-Series LS1 "Cracked Rod" Connecting Rod Bolts $152.99
ARP134-6006 ARP High-Performance LS1 "Cracked Rod" Connecting Rod Bolts
Old Oct 25, 2004 | 11:12 AM
XCELER8's Avatar
XCELER8
Its ok, you are not the first nor the last. My motor got pretty messed up with a Maggie on it w/ in a few days. I as well have a procharger going in with a forged bottom.
Jon
Old Oct 25, 2004 | 11:23 AM
XCELER8's Avatar
XCELER8
Dont over do it and try to do it yourself. Call one of our tuners over in the states to try to get all the parts you will need. They would be more than happy to give you the parts you need to asemble everything. You can call David at MTI 281-870-8787 and I am SURE he will give you awesome prices and fair shipping to your country.
Jon
Old Oct 25, 2004 | 11:41 AM
MRC5's Avatar
MRC5
Jon
i live out usa ... there is no tuner here ...
Old Oct 25, 2004 | 12:26 PM
MIKE-C5's Avatar
MIKE-C5
I went from the 346 to a 383, My heads are Stage II, Custom Pistons and my CR is 9.3:1
I will be running a D1SC with a 3.85 pulley to start.
Old Oct 25, 2004 | 12:46 PM
XCELER8's Avatar
XCELER8
I know this...LOL Most of the parts you are going to buy to forge your car wont be from your country. I am saying call one of our awesome tuners stateside and get their advice on what to go with as well as you are able to buy it from them for a decent price. They can help you decide on compression and so on for your specific aplication.
I have 9.0 on my new setup just incase you were curious.
They also are very reasonable on shipping.
Jon
Old Oct 25, 2004 | 03:56 PM
Terry Burger's Avatar
Terry Burger
If you don't get it tuned right you'll pop your forged motor just as quickly.
Old Oct 25, 2004 | 03:59 PM
Z06GMAN's Avatar
Z06GMAN
St. Jude Donor '06
YEP
good luck
To rebuild forged bottom
Old Oct 25, 2004 | 04:58 PM
XCELER8's Avatar
XCELER8
ECS just listed a thread on here that Chris is doing Mail order tuning for SC cars..This is your chance to have a great company tune you from a far.
Jon
Old Oct 25, 2004 | 05:38 PM
mdhmi's Avatar
mdhmi
Sorry to hear your motor failed soo quickly. Save yourself a lot of time and money and get your replacement motor from one of our top-notch vendors (ECS, for example). ECS can also supply you with a tune that should keep the new motor living a lot longer than your old one.
Good luck,
Mark
Old Oct 25, 2004 | 08:19 PM
MRC5's Avatar
MRC5
Good luck,
Mark
thanks pro.
