Question about limiting boost....
Old Nov 17, 2004 | 10:26 PM
dads01dream's Avatar
dads01dream
Default Question about limiting boost....
on a supercharged Vette. I am starting to see 10+psi now that it's getting colder and I *really* don't want to grenade my motor.... just yet!
Could a wastegate controller from a turbo system somehow be used to set a limit to boost pressure on my D1-SC blown car?
I have had my oil dipstick go POP two times this week due to excessive boost, I'd really like to correct this over-boosting situation before something seriously bad happens.
Any suggestions??
Old Nov 17, 2004 | 10:31 PM
DDSLT5's Avatar
DDSLT5
Any suggestions??
Gas-X?
Old Nov 17, 2004 | 10:41 PM
dads01dream
Gee... how about a useful suggestion?
Old Nov 17, 2004 | 10:45 PM
blownchevy's Avatar
blownchevy
I would suggest a larger supercharger pulley. Who's supercharger do you have?
Old Nov 17, 2004 | 10:50 PM
dads01dream
I have the A&A kit installed by ECS, we're using the largest available pulley now. During the summer my boost was just fine, but now with the colder air the D1 is simply producing too much boost. :o
Old Nov 17, 2004 | 10:53 PM
Z1500's Avatar
Z1500
When using this method to limit boost on a supercharger you use a pop off valve. This is a little different from a blow off valve (BOV) in that a BOV is only meant to open when the throttle plate is closed to relieve pressure between TC/SC and throttle plate. A pop off valve you would not run a vacuum source to the top, it's only held closed by spring pressure. You adjust this spring pressure to give you the desired pop off boost level. The advantage to this method on a SC is you can use a smaller pulley to get you more boost sooner in the RPM band but then relieve the excess pressure you don't want on the top end.
Kevin
Old Nov 17, 2004 | 10:55 PM
blownchevy's Avatar
blownchevy
HMMM, I would contact A&A and see what he has to say about that. I am not sure the above idea (BOV) will be in expensive.
Old Nov 17, 2004 | 10:56 PM
mdhmi's Avatar
mdhmi
I wouldn't step up the pulley size - as soon as it gets warm again and your boost drops your going to want the smaller pulley back.
We are both in the same situation as far as wanting to at least maintain our current hp levels while running lower boost.
All I've been able to come up with:
-- LT's (which you already have)
-- Reduce your RPM - max it at 5800 instead of 6300 for example.
-- Better flowing heads - larger CC's - lower compression.
Cheers,
Mark
Old Nov 17, 2004 | 11:03 PM
blownchevy's Avatar
blownchevy
The pulley is easy and cheap. Why would you not swap back and forth. 30 min install, MAX. drop it 2 psi and throw some timing at it.
Old Nov 17, 2004 | 11:31 PM
IM QUIKR's Avatar
IM QUIKR
I seached high and low and swapping pulleys is the only solution. What I found out was that a SC is different from the turbo in that a pop off valve reduces pressure too drastically on the SC and will screw with the head unit with violent pressure changes. If you could slowly/easily bleed off boost with a valve, the blower will continue to work harder because the back pressure is disapating and this translates into more heat generated in the air charge....and then my eyes glazed over at this point . But you get the drift. The only thing you can do is slow down the blower.
Old Nov 17, 2004 | 11:53 PM
dads01dream
Well, the problem I have is we're already using the LARGEST pulley on there (I believe it's 4.5"). Short of making a custom 4.75" or 5" and absoluting KILLING my power production.... there's got to be a way of rigging up some sort of electronic/progressive wastegate controller??
Unfortunately, I just haven't got a clue how to do it OR if it'll even work for that matter. I've got to think the issues of pressure dissipation whether it be with a turbo or blower are the same... at least I hope! If I'm correct, then maybe some "Ricer kid" out there knows how to make me effectively reduce my boost and then CRANK'ER UP again as desired. Anybody know someone that owns a Supra?
Heck, I may even be able to go with that smaller pulley somebody mentioned above if this can be done?? Any other thoughts? Maybe our TT brothers on this Forum could give me some suggestions?
Thanks guys!
Oh, one more thing.... I like your idea Mark about putting on some different heads!!! Yet another good reason/excuse to modify the Vette.
Old Nov 17, 2004 | 11:59 PM
mdhmi's Avatar
mdhmi
I'm here to help . Sounds like you might need the AFR 225's and an ECS alky kit - for safety purposes only .
Mark
Old Nov 18, 2004 | 12:06 AM
dads01dream
EXACTLY, Mark! The car can never be too safe. :o
Old Nov 18, 2004 | 12:17 AM
DDSLT5's Avatar
DDSLT5
Remove the supercharger?
I know, I know - tell your wife how much you've spent, and she'll hammer one of her heels into the intake plumbing, thus limiting the boost indefinitely!!
Old Nov 18, 2004 | 12:27 AM
Yano's Avatar
Yano
I would say try some 6.0L heads, go with a thicker gasket to decrease compression ratio even further. Plus you dont have to rev it up to redline, maybe short shift the car during the cold days.
Old Nov 18, 2004 | 12:40 AM
QuickSilver2002's Avatar
QuickSilver2002
This may sound crazy to some of you, but I think it will work. Weld a small threaded pipe 1'-1.5' or so into your pressure tubing near the BOV (after the intercooler). Let it vent and you will make about 2-3 psi less. It is ends up being an intentional boost leak. Cap it in the summer and you will make the desired boost again.
I know it sounds too simple, but I think it will work. I took off my BOV once when I only had a 1.5" or so flange on it and I still made decent boost.
Old Nov 18, 2004 | 02:04 AM
Av8ter's Avatar
Av8ter
Well, the problem I have is we're already using the LARGEST pulley on there (I believe it's 4.5"). Short of making a custom 4.75" or 5" ...:
Verify exactly which pulley you have. I have the 4.63 pulley installed on mine and i just checked the parts list from the ATI sheet and they do have a 4.75 listed as the largest. I dont know if any other sizes have been designed since ive had this parts sheet because its been at least 2 years.
To Question about limiting boost....
Old Nov 18, 2004 | 02:31 AM
MelloYellow's Avatar
MelloYellow
The problem with using a BOV/Wastegate type setup with a supercharger is that when you run a small pulley and then let off the boost without using it, you continue to have the parasitic horsepower loss of driving the blower off the crank.
All of the extra power to drive the supercharger is wasted and is a constant drag on the system. Also increases intake temperatures negatively.
Boost leaks may throw your tune off as too rich if the air has been metered by the MAF already.
Old Nov 18, 2004 | 09:18 AM
dads01dream
Thanks Quick.... I'll look into your suggestion & discuss it with Doug or Chris @ ECS (I've got an alky kit to order today!!!).
Thanks Av8ter.... I'll measure my pulley to see *exactly* what's on there. I asked Andy @ A&A for the biggest pulley to really limit boost, I "thought" he mentioned to me it was a 4.5" size.
Thanks Yani & mdhmi.... The idea of using bigger heads and thicker gaskets really makes a TON of sense! Both for increased power production and safety.
To DDSLT5.... The only time that blower is going to come off is to install my new forged motor!!! Of course, then the blower would be put RIGHT BACK ON!!!!
Does anyone have some thoughts about how to stop my oil dipstick popping issues? Thanks!
Old Nov 18, 2004 | 10:22 AM
Sack Rat TT's Avatar
Sack Rat TT
Does anyone have some thoughts about how to stop my oil dipstick popping issues? Thanks! [/QUOTE]
Do more research before you use thicker gaskets as was done in the OLD days. Different burn pattern and flame front in these motors and added space between top of piston and head is all part of a design marriage.
I am using a spring to hold my dipstick in place with no problems.
