Can you decrease timing to your advantage?
Old Jan 23, 2005 | 08:26 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Default Can you decrease timing to your advantage?
If you had a car that made too much power down low, could you simply decrease spark timing down low to help reduce traction problems?
Old Jan 23, 2005 | 09:32 PM
RoadRebel's Avatar
RoadRebel
Yes you can...But I think you will be fine with your stuff .
Worse case you can adjust the boost controller to slow the rate at which the boost comes in. If its a blitz you can even scamble boost based on time in seconds. Example channel 1 is set to 12 psi and scramble enabled. you set the time for 3 seconds and the level. so, You could do 6 psi for 3 seconds then it hits full boost.
Problem more likely will be traction up top at full boost. Thats a bit spooky and why I have been trying to optimize the traction control model.
Phil
Old Jan 23, 2005 | 09:39 PM
MelloYellow's Avatar
MelloYellow
I've been doing some TCS optimization lately also. Are you talking via PCM/LS1Edit or just by playing with a boost controller?
Old Jan 23, 2005 | 09:58 PM
RoadRebel's Avatar
RoadRebel
Both..
You can do quite a bit to make the tcs allow a more agressive application of power and when it does you can minimize the severity of application of the model.
and, for us turbo guys we can play with the boost comtrol too
Phil
Old Jan 24, 2005 | 02:30 AM
MelloYellow
For an M6, what setup are you using on the LS1Edit TQ Control Tab?
Interested in all your tweaks, but I've been focusing on TCS Retard vs. RPM lately.
TIA!
P.S. C5 TCS is applied via Ignition Timing and Throttle Control, but not brakes, correct?
Old Jan 24, 2005 | 07:48 PM
Slowhawk's Avatar
0Slowhawk
Former Vendor
Why not just learn how to control the throttle input?Like,don't mash the throttle
Old Jan 24, 2005 | 08:03 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
I totally agree with learning the pedal and not stabbing the throttle, but there is something to be said for tuning a car for better streetability -- and my goal for my car has always been to have a fast *** daily driven street car. So I personally don't see anything wrong with extending the longevity of my tires and driveline by not instantaneously delivering ridiculous amounts of torque.
Old Jan 24, 2005 | 08:04 PM
Vince99FRC's Avatar
Vince99FRC
Ramchargers Timing Tuner. You can reduce the timing easily. It has a base timing setting and a below and above 3krpm setting...
To Can you decrease timing to your advantage?
