Homelink Mirror
Old Jan 26, 2005 | 06:26 PM
Yello04's Avatar
Yello04
St. Jude Donor '05
Default Homelink Mirror
I know that a while back I had seen information on a Homelink mirror that had garage door opener and a compass built in. I had one on my 350Z.
Anybody have one or know of one for the C5? If so, where can I get it and at what cost?
Thanks.
Old Jan 26, 2005 | 06:37 PM
14U2ENV's Avatar
14U2ENV
From: Lino Lakes, MN _________________________ I Figured out how to do this!
St. Jude Donor '04-'05-'06
Mito and Gentex make them. At one point one of the supporting dealers was working on it but I think that well thru the cracks.
Here is the Gentex
http://www.aaaremotes.com/geaurevimiwi.html
Old Jan 26, 2005 | 06:59 PM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
Ken Fichtner Chevrolet is still working on a fully integrated GM or equal rear view mirror. The issue, I'm told is licensing the plug. Best,
mtv
Question for 14U2ENV:
is the Gentex unit plug and play with the GM plug?
Old Jan 26, 2005 | 07:07 PM
14U2ENV's Avatar
14U2ENV
mtv
I don't know, I was holding off on this until I head what the deal was on Fichtner's fix and said the heck with it. I went a different route (visior) for the Homelink.
Old Jan 26, 2005 | 07:11 PM
JTS97Z28's Avatar
JTS97Z28
Gentex will likely not be plug and play. It comes with its own wire harness which includes temp sensor. The new ones are pretty sweet they also come with LED maplights and dual line temp / compass.
Old Jan 26, 2005 | 07:25 PM
Kanon's Avatar
Kanon
Here is the Gentex
Would you lose the courtesy interior lights if you went with the mirror solution? If this is true, the visor solution might be better.
Old Jan 26, 2005 | 10:06 PM
Yello04's Avatar
Yello04
St. Jude Donor '05
Thanks for the info. I'll check out the Gentex.
What can you tell me about the visor option?
Old Jan 26, 2005 | 10:08 PM
Yello04's Avatar
Yello04
St. Jude Donor '05
Never mind. I saw the Gentex visor option.
Thanks.
Old Jan 26, 2005 | 11:21 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Got mine off eBay. Fairly easy install.
Old Jan 27, 2005 | 12:44 AM
JTS97Z28's Avatar
JTS97Z28
How do you like it? and how do the LED maplights look?
The only downside to this is I really like the little amber "moodlight" mounted under the stock mirror that gives the center counsil some light at night. Looks cool. I wonder if this light can be somehow mounted in the Gentex.
Old Jan 27, 2005 | 01:20 AM
Jay04C5's Avatar
Jay04C5
I installed the Gentex and think it works very well and looks great. You need to order it with the map light option to replace the functionality of the stock mirror. With the map light option you can set it to give the dim light over the shifter when it is dark. It was not difficult to mount or wire, but it took me about four calls to the tech support line to get the pin-out connections to control the outside driver mirror's dimmer.
Here is one more link to see the mirror.
http://www.autotoys.com/x/catalog/MI...DLX_p_860.html
Old Jan 27, 2005 | 01:52 AM
MTV's Avatar
MTV
Does the C5 plug fit the mirror or is there a new plug that has to be wired to fit the mirror? Not dificult for you could mean very frustrating for guys like me with lots of thumbs! Anything you can recall about the pin-out connections would be helpful. Best,
mtv
To Homelink Mirror
