No more washer fluid?????
Old Jan 27, 2005 | 08:44 PM
VA CORVETTE 757's Avatar
VA CORVETTE 757
Default No more washer fluid?????
I replaced the washer fluid motor and checked the fuse so far but still no luck? Any suggestions-- the stealership might rape me if i take it there.
Old Jan 27, 2005 | 09:57 PM
wolfmd's Avatar
wolfmd
Yoiu should bring this up on the Tech forum. You may find some useful help there.
Old Jan 27, 2005 | 10:28 PM
jrose7004's Avatar
jrose7004
Old Jan 28, 2005 | 12:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Did you check the fuse for the washer pump??
BC
Old Jan 28, 2005 | 10:17 AM
1Patriot's Avatar
1Patriot
Is there fkuid in the tank??
Old Jan 28, 2005 | 10:56 AM
ericdwong's Avatar
ericdwong
Or are the lines frozen?
Old Jan 28, 2005 | 02:29 PM
VA CORVETTE 757
No the fuse is fine and motor was replaced. It's either the lines, ground, or wiring probably?? Who knows.. I'll get it eventually, just a small problem.
Old Jan 28, 2005 | 02:34 PM
srchief100's Avatar
srchief100
Kevin,
Just a thought here (dangerous for me) but if your washer was down for awhile you might check the lines. There may be some crap built up in the lines. Happens with A/C systems so why not the washer system. Anyhow just a thought
Old Jan 28, 2005 | 02:37 PM
VA CORVETTE 757
What do you I need to do to clear the lines???
Old Jan 28, 2005 | 02:47 PM
srchief100's Avatar
srchief100
Disconnect from the pump - and from the point where it sprays onto the windshield and clear out the line with compressed air (can's available at Radio Shack, Wal-Mart, or any computer place). Or if your cheap and impatient like me, take a deep breath put one end in your mouth and blow like hell.
Old Jan 28, 2005 | 02:50 PM
VA CORVETTE 757
Hahhaah i have an air compressor and if that doesn't work looks like i will put my lungs to work. ahahah thanks!
Old Jan 28, 2005 | 02:51 PM
VA CORVETTE 757
I'll try my air compressor first, then my lungs!!!
To No more washer fluid?????
