Clacking Noise under acceleration **HELP**
Old Jan 28, 2005 | 01:53 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Default Clacking Noise under acceleration **HELP**
OK Guys, I just got done installing my new KOOKS headers and Tunnel plate from elite engineering tonight. (Actually I didn't my local shop did)
Well, they claim to have had a Bit@@ of a time doing it and had to move the motor out of the way to get them to fit.
Anyways, They delivered the car to my work and the manager told me that he thought I had eith a lifter problem or maybe a bent push rod. Cause when your under acceleration (Decently Hard not WOT) when you pass 3.5 to 4K rpm the motor starts making a clacking noise. but not really a metal to metal clunking.
It goes away after about 600rpm. What could this be??? He seems to think it was there before the header swap but the KOOKS made it noticeable.
They did drive my car 40 miles back to me and I really dont feel they had any business taking my car to 5K rpm. Could they have done something to it. They are very knowledgeable and had quite a few C5's in the shop. I dont know why they would have wanted to toy with my car it's pretty much stock...
What could this be cause I'm clueless...
BTW, It a 2000 C5 M6 with 43,000 miles
Old Jan 28, 2005 | 02:12 AM
NSTG8R's Avatar
NSTG8R
i think my first question to them would be what the hell are you doing taking my car up to 5 grand, if it wasn't there before I'd blaim it on them.
and if they dispute tell them to remove the headers and then we'll find out if it was them or not.
Old Jan 28, 2005 | 07:41 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
My Guess
99% sure you have an exhaust leak. Probably the header gasket (I am guessing they tossed the excellant stock metal ones in favor of crappy aftermarket paper ones). It could also be the O2 tube connection is not made correctly. Either way it is likely an exhaust leak. And YES when it is a header gasket - it makes an AWFUL racket - just like a stuck lifter or screwed up rod (I have had this happed a few times on other hot rods).
My main fear is they may have crossthreaded a bolt during the install and that caused the problem. It could also be they tore the aftermarket gasket during installation.
Old Jan 28, 2005 | 10:57 AM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Originally Posted by Ragtop_Rob
My Guess
If this was an exhaust leak wouldn't you hear it all the time?
When the car is idling its dead quiet. It only becomes apparent for about 600-700 rpm under acceleration.
And to be able to hear it with your windows rolled up at 3500 RPM and Kooks headers with high flow cats and B&B Bullets, "You know its gotta be loud"
Old Jan 28, 2005 | 03:07 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
There has got to be more answers than this!!! C'mon guys I really need some input before I drive 300 miles to Xtreme to find out its something stupid...
To Clacking Noise under acceleration **HELP**
