Help!!!
Old Jan 31, 2005 | 03:21 PM
chriscostas's Avatar
chriscostas
Default Help!!!
I was dropping my 02' Z51 suspension Vette this weekend. When i got to my last bolt on the driver side front the bolt to turn was way tooo tight! After a while of trying and a long story short, the bolt head got stripped and the head of the bolt broke off.....what do I do? anyone please help thank you if anything my e-mail is chriscostas@bellsouth.net
Old Jan 31, 2005 | 03:43 PM
LV_2_XLR8's Avatar
LV_2_XLR8
Sorry, but the only choice you have is to drill the bolt out and try to remove it in pieces. I doubt if an "easyout" will work in a bolt that tight. Besides, I think it's a grade 8 bolt.
It's got to be one of the weakest feelings ever, when you snap a bolt off in an area like that. I feel bad for you. Good luck.
Old Jan 31, 2005 | 03:47 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Old Jan 31, 2005 | 03:55 PM
Bman's Avatar
Bman
St. Jude Donor '05
Dont agree,
Are you taking the pressure off the spring? Mine were so tight before I
took the pressure off. After I took the pressure off I could turn it with my hand. If you cant do it with your hand Im sure an extraction tool will do the trick..
Old Jan 31, 2005 | 03:58 PM
chriscostas
I can't even grip the bolt unless with a vice-grip. My plan is to just replace the bolt itself somehow. The problem with that is that they don't sell that bolt of the mono-spring by itself...
Old Jan 31, 2005 | 04:21 PM
Bman's Avatar
Bman
St. Jude Donor '05
Sorry my bad. Leaving the tension on the spring use a bolt extractor and
drill in until it catches. Release the tension on the spring and back it out.
The bolt should not be a problem to get try a good hardware store.
Make sure its the right grade bolt..
Old Jan 31, 2005 | 04:22 PM
Bman's Avatar
Bman
St. Jude Donor '05
I just saw your in Miami, Let me know if you need a hand..
Old Jan 31, 2005 | 04:38 PM
MSGvette's Avatar
MSGvette
Maybe this will helphttp://forums.corvetteforum.com/showthread.php?t=1001648
Old Feb 3, 2005 | 01:20 PM
chriscostas
Thanks for all the info. What I have been told by a local Corvette shop is that i would need to replace the mono-spring as it is seized? is this true?
Old Feb 3, 2005 | 04:37 PM
jaxgator's Avatar
jaxgator
From: Time is a great teacher. Unfortunately, it kills all its pupils.
Cruise-In VIII Veteran
St. Jude Donor '07
It sounds to me that you were attempting to lower your car, right? If so, check out this C5 tech tip. If you follow this procedure, you ought to be able to remove the bolt from the bottom side of the mono-spring and either replace it or leave it completely out and remove the passenger side as well.
Good luck and be careful.
To Help!!!
