Side Exhaust
Old Jan 31, 2005 | 06:35 PM
canadianguy's Avatar
canadianguy
Default Side Exhaust
Has anyone put a side exhaust mod on there C5, like the late 60's 454? Is this even possible, if any one has done it, can I see pics please.
Old Jan 31, 2005 | 06:42 PM
HERK's Avatar
HERK
just my 2 cents.
Old Jan 31, 2005 | 06:53 PM
400hp's Avatar
400hp
I don't think it's possible given the small tunnel in the center of the car for the exhaust routing. If you went below this height it would be too low. There is no way to route it to the side.
Old Jan 31, 2005 | 06:56 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
Look closely at the C5-R.. It`s not sidepipes, but the exhaust exits out the side.
Old Jan 31, 2005 | 07:00 PM
eddie44's Avatar
eddie44
St. Jude Donor '03
Jack up your C5 and you'll see the exhaust is pretty close tolerance in the tunnel. If you weren't driving it on the street, ie the C5R then you could run it out the side or a true side exhaust. I don't want to be negative but I agree with . This is a C5, not a C2 or C3. Just my .02 but it's your Vette.
Old Jan 31, 2005 | 07:03 PM
canadianguy
I appreciate everyone's input, I am not really thinking of doing that. Just wondering if possible, and I was curious to see some pics if available. What about a side molding made for the pipes to exit?
Old Jan 31, 2005 | 07:06 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Are there legal issues with sidepipes?
Old Jan 31, 2005 | 07:15 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Not enough clearance on the street, even at stock height. Lowered? Forget it. The bottom of the C5 is as flat as a pan - nowhere to route 2.5 to 3inch pipes, unfortunately. I love the exit-in-front-of-the-rear-wheels look (yes, yes, Rice.. so what?) but even with flattened pipes I can't see how it would be physically done and the car still driveable.
Lowered to the max on stock bolts, my car is exactly 4inches from the ground in the middle, 3inches in the front. So 2.5inch pipes with a little clearance between the chassis and the pipes and you're about an inch off the ground.... not good (unless you are ALLKAR )
Remember... Just 4 inches clearance..
Just 4 inches between butt and bitumen
Just 4 inches between a$$ and asphalt
Just 4 inches between tush and tarmac
Just 4 inches between posterior and pavement
And my car is going down another inch...
I would be interested if anyone could pull off this sleight of hand.
EG
Old Jan 31, 2005 | 07:23 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
[QUOTE=EnglandGreen]
Damn bra, what'd you do take out the seat and use the floor board for your keister.
Old Jan 31, 2005 | 07:26 PM
0EG@EnglandGreen
Supporting Tuner
I'm ridin' loooowww
Old Jan 31, 2005 | 07:30 PM
Target Chaser
St. Jude Donor '05
Originally Posted by EnglandGreen
I'm ridin' loooowww
I'll be down there with you to, real soon.
Old Jan 31, 2005 | 08:29 PM
Considering how low the car sits and how the exhaust would have to be run, I think doing this would cause all sorts of scraping problems, even when you go over the slightest bump.
Old Jan 31, 2005 | 09:36 PM
leaftye's Avatar
leaftye
On the C5-R they still have to use the frame rails, so they probably run the pipes into the rails right next to the engine bay and keep it inside till the exit points.....or they could come all the way thru and run outside the rails and inside extended rocker rails. On a race car that sees speeds that the C5-R sees, the center tunnel could be used for a venturi tunnel, or simply closed off to create a flatter bottom.
Old Jan 31, 2005 | 09:42 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
...with all of the above.
Brings to mind my '74 Camaro on which I put "glass-packs" side-exhaust pipes. I'm telling ya, the constant drone after awhile, REALLY got on my nerves. Sounded cool and all, but still the noise. And that was when I was 23.
Worse, it devalued the car when I went to trade it in for a TR7, which is another story completely.
Old Jan 31, 2005 | 09:56 PM
Cajun99's Avatar
Cajun99
No thanks...I'd pass...I'm perfectly happy with my out-da-azz Stingers
Old Feb 1, 2005 | 01:08 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
To much trouble.
Old Feb 1, 2005 | 01:11 AM
12stepvette
Originally Posted by Stock Man
To much trouble.
Agreed!!
To Side Exhaust
Old Feb 1, 2005 | 01:18 AM
NSTG8R's Avatar
NSTG8R
unfortunately the corvette is no longer (and some would argue never was) a muscle car. It's a sporty exotic type and side exhausts well, just dont overly fit into that picture. I too loved the side exhaust and enjoy the viper's attempt at throwing this back yet I just cant see it on a c5.
Old Feb 1, 2005 | 03:29 AM
Mike2013's Avatar
Mike2013
St. Jude Donor '03-'26
if you have the $$$$ I'm sure it can be done.
Old Feb 1, 2005 | 06:40 AM
Jeffyvette's Avatar
Jeffyvette
Default C4 side exhaust
I have side exhaust on my C4 race car. This is not the sytem you can buy out of Ecklers that goes around from the back turns 180 degrees then back down the side. Due to the fact the car is very low we made custom headers that go over the frame rail then under the trim under the door and exit mid-door. The actual exhaust pipes are 18 inch long. It is very loud no mufflers 410 ci displacement, 14:1 compression, big *** cam. So may be able to be done but my mechanic said if he ever made another set of headers like this he would charge $3000 for all the work in them.
Jeffy'
