New Member Question
Old Jan 31, 2005 | 09:17 PM
metroff's Avatar
metroff
Default New Member Question
Although I've been reading the Forum religiously for months, this will be my first post.
I have a '03 6-speed coupe. Of late I have been noticing a fluttering noise coming from the engine compartment, it is especially noticable when I am accelerating and the RPM's are above 3,000. I checked under the hood to see if I could pinpoint where the noise is coming from. My best guess is that it seems to be coming from the fan belt. It seems like it might be a bearing in one of the gears. Has this happened to anyone? Any ideas on what it could be? Any help would be greatly appreciated. Thanks....
Old Jan 31, 2005 | 09:27 PM
Poptops's Avatar
Poptops
You probably need someone to gently raise the rpms while you're looking into the engine compartment. Any "fluttering" if it's significant should be visible and if it's an idler bearing; water pump; whatever; it would be more noticable with the hood up. Good luck.
Old Jan 31, 2005 | 09:41 PM
Scratch's Avatar
Scratch
Veteran: Marine Corps
St. Jude Donor '03-'04-'05-'09
What poptops said. Get her looked at if nothing else.
Old Jan 31, 2005 | 10:05 PM
GrayC5's Avatar
GrayC5
Welcome to the Forum!
Don't know that I can help but pehaps this might give you a start:
Old Jan 31, 2005 | 10:22 PM
GrayC5's Avatar
GrayC5
I don't have any answers for you, but perhaps this might help:
Troubleshooting V-ribbed Belt Noise
Also, there is an tensioner pulley and idler pulley for both the main drive belt and the AC belt. Bearings in these have been know to go bad so you might want to check these too. There has been several posts here in the past on the tensioner and idler pulleys. If you can get the Forum search feature to cooperate, you may be able to find some of these. You can also find a little more info on this here:
1997-1998: Service Bulletin: Belt Rumble Noise at Low Idle Speeds
1997-1999: Service Bulletin: Accessory Drive Squeak (Replace Idler Pulley)
Good luck with the fix.
Old Feb 1, 2005 | 12:12 AM
Stock Man's Avatar
Stock Man
2015 C5 of Year Finalist
St. Jude Donor '05-'06-'07-'08-'09-'10
We I think the others took care of you. So I'll add my Welcome to the forum.
Old Feb 1, 2005 | 08:55 AM
ALLEGRO's Avatar
ALLEGRO
Me too !
Welcome and good luck
Old Feb 1, 2005 | 09:26 AM
Rou-Rou 03's Avatar
Rou-Rou 03
Your 03 should still be under waranty Find the a good dealer in your area and have checked
Old Feb 1, 2005 | 09:28 AM
JACKAL0PE's Avatar
JACKAL0PE
Lepus-temperamentalus
You lurked for months before making a post???
We don't bite you know. Don't make your first post your last! Enjoy the forum. Participate! It's a lot more fun reading if people are talking back to YOU!
Welcome! C'mon and jump right in!
Old Feb 1, 2005 | 09:29 AM
C5 4 ME's Avatar
C5 4 ME
Old Feb 1, 2005 | 10:19 AM
Oldad's Avatar
Oldad
CI 6-7-8-9 Veteran
St. Jude Donor '07
Hello and welcome
Find dealer or shop you can trust and help them find it.
Hope its an easy fix
Old Feb 1, 2005 | 10:57 AM
MSGvette's Avatar
MSGvette
You should find a Dealer you can trust. Your vette is still under warranty. Welcome to Forum
Old Feb 1, 2005 | 01:09 PM
Welcome and good luck in finding the source of the noise.
Old Feb 1, 2005 | 01:12 PM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
Hello and hope the fluttering is an easy fix
Old Feb 1, 2005 | 01:18 PM
bogiemanjoe's Avatar
bogiemanjoe
With Jackalope. The problem its very addicitve in here
so have fun and welcome. ..and get the vette checked out by a "Good dealer" You should still be under warranty. Good luck, now like I alwasy say...Pictures, pictures we like and want pictures.
To New Member Question
