active handling warming up?
Old Feb 2, 2005 | 04:09 PM
lvvette777's Avatar
lvvette777
Default active handling warming up?
I drove my car for about 1 solid hour today so it was nice and warmed up.
Then I turned on the competitive driving and did a SMALL burn out. After that the message on my DIC kept flashing "active handling warming up".
It wouldn't stop until I turned the car off and turned it back on, now it's fine.
Any ideas?
Old Feb 2, 2005 | 04:11 PM
srchief100's Avatar
srchief100
I've had the warm up message occur shortly after starting out after being parked for awhile but never as you described. So now I am curious about this also.
Old Feb 2, 2005 | 04:21 PM
DavesC5's Avatar
DavesC5
That's the same thing mine does. I park in a parking ramp at work and there are a lot of turns and braking involved in leaving the ramp and that seems to trigger the warming up message. If I start out and basically drive in a straight line, it doesn't do that.
Old Feb 2, 2005 | 04:23 PM
REDRWUT's Avatar
REDRWUT
mine does the same thing when i first start up and drive real slow, like 10 mph. the reason i drive @ 10 mph is because there is a limit because of little kids on bikes, but afer a couple of minutes it is ok.
Old Feb 2, 2005 | 05:30 PM
roscoe118's Avatar
roscoe118
Mine has done this several times. Not to worry. Sounds like you are driving it like it was meant to be driven . It does seem to happen more often when the car isn't warmed up (first few miles after starting).
However, mine has always cleared without having to restart the car. That part of it seems a bit out of sorts.
Old Feb 2, 2005 | 10:38 PM
charlieb's Avatar
charlieb
I had posted the same question (happened during autoX). The answer was to drive it in a straight line above 6mph for about 200 feet. That calibrates it to learn where "straight is". Seems to work.
Old Feb 3, 2005 | 12:05 AM
Bill Dearborn's Avatar
Bill Dearborn
Charlie is right.
Bill
Old Feb 3, 2005 | 01:18 AM
lvvette777's Avatar
lvvette777
Thank you very much!!!!!
To active handling warming up?
