I believe it is the pink wire. I cut the pink wire back by the antenna and installed a toggle switch so that I can keep the antenna down while listening to CD's.
That wire (pink) is what I also cut for the switch to control the antenna.
I put a switch on my 91, worked great.
Now have one on my 99 - great again...
I rarley even raise the antenna, get good reception around town with it down.
It's just something about the antenna going halfway up, then down, then all the way up each time I start the car. No worries now.
