Touch Up Paint
Old Feb 4, 2005 | 07:48 PM
Icemanskis's Avatar
Icemanskis
Cruise-In VI Veteran
St. Jude Donor '05
Default Touch Up Paint
Hey guys,
My 2000 pewter coupe has about 3 light scratches on the surface of the front fascia (all thanks to the SOB that owned the car before me). You can't see them from a distance but it bothers my obsessive compulsive nature. I have tried buffing out the scratches to no avail. I have seen GM factory matched touch up paint advertised....is this a good way to go or am I just asking for trouble. Any ideas on how to fix/cover up the scratches at a reasonable cost? Thanks
Brian
Old Feb 4, 2005 | 08:30 PM
Blue Lion's Avatar
Blue Lion
I have the GM touch up paint in the small bottle and the spray bottle. They both match my navy C5 well.
Old Feb 4, 2005 | 08:31 PM
Corpsvette's Avatar
Corpsvette
Veteran: Marine Corps
Hey,
I am far from a scratch fix pro but I order all my Spiral Grey touch up paint from here. I have ordered their small pens to their spray cans. The paint has always matched. I don't particularly like the paint pens but the other products were good.
http://www.paintscratch.com/
To fix the scratch, I would use the color paint and build up layers. Once it was bubbled/formed a bump above the rest of the paint and dry, I would use 3M scratch remover and a cloth and rub it down with very small circular motions until the scratch area was level with the surrounding paint. Then I hit it with clear coat and let it dry real good then use the 3M scratch remover until I was happy with the work. I would challenge people to find the fixes. Just be patient. There is also Langka or something but haven't used it. Someone else can comment. Good luck.
Jim K.
Old Feb 4, 2005 | 09:35 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
My suggestion is before you go blobbing on touch up paint. Check with a local bodyshop and see if the scratches can be wetsanded and buffed out.
I can't tell you how many times in the last 20sum years customers have brought their cars in to have touch up paint wetsanded and buffed and once removed, there was nothing underneath but a light, light scratch....
Just a suggestion from one obsessive compulsive vetter to another... LOL.
Mark
Old Feb 4, 2005 | 09:56 PM
Icemanskis's Avatar
Icemanskis
St. Jude Donor '05
Mark
Thanks for the replies everyone.
Mark, do you own a bodyshop? Any ideas for a price estimate on the process you mention?
Old Feb 4, 2005 | 10:00 PM
H82GOSLW's Avatar
H82GOSLW
I was going to go the bodyshop route to fix the numerous chips located on the front end, but the cheapskate in me decided to go the touch up paint (purchased from a chevy dealer) route. If you are as OCD as you say, you will not be satisfied going with this option. I am usually not overly particular about this kind of stuff and I think it looks like crap on my car. From far away you can't tell, but a closer look reveals that the touch up paint does not blend in perfectly.
Old Feb 4, 2005 | 11:57 PM
MyBlueC5's Avatar
MyBlueC5
Corvette ***** OG
St. Jude Donor '05
CI VI Veteran
Yes sir, I do own a bodyshop. Graduated in Civil Engr'ing, been in the bodyshop business for 20 some years.
As far as cost, it depends on what is being done. If it's just a couple of scratches (3 or 4) and they're being wetsanded and buffed, it's not a big deal, I usually don't charge for it. Even at most if they're quite a bit more, I don't charge more than an hour's labor. (40 bucks)
Many times if the scratches are really deep and the customer doesn't want to do any physical painting, I'll brushtouch the scratch, let it dry, repeat and continue until it's almost built up. Once it's almost filled, I'll add some activator to a bit of clear and fill the rest of the scratch with clear.
Once dry, I wetsand and buff the area. Point is, if the scratch can't be wetsanded and buffed, the previous method is an alternative to refinishing an entire panel.
HTH's,
Mark
PS. Again, depending on the amount of scratches, this could be from 50-100 bucks.
To Touch Up Paint
