Oil Pressure 80% !!!!!!!!!!!!!!!!!
Yesterday my oil pressure jumped to 80% and is still there today???? I turned car off and just turned key but did not start car and it still showed max 80%!!! Is this a normal problem???? Thanks for any input. It is kinda scaring me!
Most likely the oil pressure sensor failed. Go here http://forums.corvetteforum.com/showthread.php?t=958008 not too bad to replace yourself.
Mine did the same thing about 3 months ago. I'm going to wait until it gets warmer to do the fix, but in the meantime am I doing any damage by driving with a faulty sensor (other then if I really lose oil pressure)?
same here three days ago. my digital went to 130 psi. I think I almost went off the road when I looked down and saw it. I pulled in to 7-11 and shut it off. I turned the key on to see the temp and noticed I still had 130 psi without the car running. then I knew it was not a true reading. luckally, my car goes in next week for some luvin. (cam, headers, x-pipe, hiflow cats,corsa mufflers, adjustable roller rockers, underdrive pullies, timing chain, waterpump, hurst shifter and the LS-1 edit. I can't wait. I feel like a kid the week be for christmas!
